Question about Bose QuietComfort 3 Acoustic Noise Cancelling Consumer Headphones
Only the left earcup works, even if i change the wire, its the same. but noise cancelling works on both.
  • 3 more comments
  • Anonymous Jan 17, 2009
    Same problem but RH earphone not working
  • gerardmcd Jan 19, 2009
    same problem exactly
  • goodexcuses2 Jan 21, 2009
    same problem, love my headphones and want to fix them HELP!
  • t_r_r Jan 28, 2009
    I have the same problem. If I play around with the cord, I can get the other ear to work. I ordered a new cord, thinking that might be the problem. The only issue is, the cord is on backorder for four to five weeks!
  • Anonymous Mar 14, 2009
    I have the same problem. So, I got a new cord but the problem still remains. My guess is that the plug itself is worn out.
  • 9 Answers
They will give you a new pair for $100, even if it has been longer than a year...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Posted on Apr 26, 2009
THIS IS THE SECOND BRAND NEW SET OF QC3 HEADPHONES. BOTH HAD ONLY ONE EARPOD WORKING.
Posted on May 09, 2009
Phones get a peersing screach; itgets louder when you press the side where the on/off switch is
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Dec 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
Left Ear cup not working.
Either ship them back to manufacturer if still under waranty or you'll have to re-solder the wiring to that speaker if they have become disconnected or yanked accidentally of which the leftside is usually where the headphone cable first enters in the left side.
Oct 10, 2013 | Audio Technica ATH-ANC27 Headphones
Severe squelch in left ear phone
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
Can bose QC3 work without noisecancelling/battery?
No, the audio input must go through the active noise-canceling circuits that drive the speakers in each earcup. The noise-canceling circuits require a charged battery to operate. Unfortunately, there is no way to bypass these circuits and drive the audio input directly to the speakers.
Aug 15, 2011 | Bose QuietComfort 3 Acoustic Noise...
Hi, when I press the left eatcup close to my ear, there is this very loud high pitch noise that comes from it and is unbareable. I have to removed them inmediately. What can I do, and what those this...
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
Aug 13, 2011 | Bose QuietComfort 3 Acoustic Noise...
I have had my headsets for 3 years, they work well, I have just noticed that the left ear pad is detaching from the base. How do I get fixed?
The ear cushions are attached to the earcup with plastic tabs that snap into the plastic in the earcup. The lower snaps may be unfastened. Try pressing the ear cushion firmly to the earcup around the lower edge to refasten the snaps. Do not press in the middle of the ear cushion - you may damage the internal microphone.
If this fails, you will need to remove the ear cushion by pulling it off the earcup and inspect for broken plastic where the tabs are on the ear cushion or where the tabs attach to the earcup. If a tab is broken on the earcup, replacement earcups are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
If the plastic in the earcup is broken, you can try to repair it or you can contact Bose about getting it repaired or replaced.
Jun 11, 2011 | Bose QuietComfort 3 Acoustic Noise...
Hello, I just got a Bose QC3 on eBay. It works fine except the cable which is not the original one but a one from T'nB and the left earpiece has a very annoying whistling noise when I press it or even...
i would buy a new ear cup.and a new battery. and perhaps a new cord.
i had a problem w/ my ear cups and i noticed that when i bought the new ear cups the sound was better.
i also read that if the battery got alot of usage (4 plus year) then the whistling noise comes from that. i'm starting to have the same problem. i have had my headphones for a long time. i think like anything else that operates on batteries its time to change it.
Mar 06, 2011 | Bose QuietComfort 3 Acoustic Noise...
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the...
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Aug 02, 2010 | Telex Radio Communications
Bose QC3 makes a high pitch noise when i press it against my ear
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
My headphones are feedbacking all of a sudden
It may be time to replace the ear cushions. If so, they are available from Bose for around $35/pair.
Mar 24, 2008 | Bose QuietComfort 3 Acoustic Noise...
Bose QuietComfort  3 Acoustic Noise Cancelling  Consumer Headphones Logo
1,627 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
