Question about PNY 2GB microSD Memory Card
I have a PNY MICRO SD 2GB for my Samsung Messenger. When I put the Adapter into the computer it showed some files. One named My_Music. I put a CD in and downloaded the Cd onto the My_Music file. It showed that it existed on the computer, so I took it out and plugged it into my phone. When I went to the Music Player, it showed that there was nothing on it. So I plugged it back in the computer. It still showed that the music was on there. Just to make sure that the whole SD was ruined, I decided to put some photos on the SD. When I plugged it into the phone, all of the pictures showed up but none of the songs did. Any advice?
  • Anonymous Mar 02, 2009
    have it connected to my camera and tha camera is connected to the computer. dont know how to save anything on the micro sd adapter
  • lightblue_gu Apr 04, 2009
    I also just got a SanDisk micro SD card which is also 2GB for my Samsung Messenger and i have tried to download the files from the computer which often goes successfully but when i try to put it on my phone, it seems to not be able to locate my music. What do i need to do?
Hi. Well the problem is that your songs probably aren't recognized as mp3 files. I have a SanDisk micro SD and I downloaded a CD onto on a program such as RealPlayer or Windows Media Player first. Secondly, I dragged the files from there onto my SD. Try this but if this doesn't work then take out your micro SD and format it to your phone. This will end up erasing all that you have on there and possibly require you to do it many times just as I had to do, t eventually mine did work perfectly. I hope this works.
Posted on Sep 26, 2009
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: PNY 2GB MICRO SD MEMORY CARD NOT READING!!
In this case, it sounds like the card is bad. All you can do is try to clean the gold fingers with a soft cloth and alcohol, and hope that works. It may have corrupted data on it, and be unusable. The best way to know is to buy another one ($9 at Walmart), and then you will at least verify that your phone and computer are good, and the old card bad. Hope it's just dirty fingers, good luck.
Posted on Apr 27, 2010
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
Feb 22, 2009 | PNY 4GB microSD High Capacity Mobile Media...
How do i hook my PNY micro sd to my computer
check if the lock tab on the adapter isnt on lock
Jan 31, 2009 | PNY 2GB microSD Memory Card
Getting music onto my pny micro sd 2gb
You should just have to locate it in "my computer" open it up and drag and drop music files onto it. or just burn them on to it. e.g windows media player. if it wont let you. make sure its not locked by checking the switch on the side. Also ask your friend if he set a pin/password for this micro sd.
Jan 22, 2009 | PNY 2GB microSD Memory Card
PNY MICRO SD 2GB
Files must have the correct extension. i.e. .wav or .mp3 or whatever the music player requires. You may need to convert the sound file to a different type for the device to see it. It may show in one device and not another for this reason
Apr 09, 2017 | PNY 2GB microSD Memory Card
Saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Feb 23, 2008 | Samsung SYNC SGH-A707 Cellular Phone
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
PNY 2GB microSD Memory Card Logo
315 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
