PNY 2GB microSD Memory Card Logo
Posted on Apr 09, 2017
PNY MICRO SD 2GB
I have a PNY MICRO SD 2GB for my Samsung Messenger. When I put the Adapter into the computer it showed some files. One named My_Music. I put a CD in and downloaded the Cd onto the My_Music file. It showed that it existed on the computer, so I took it out and plugged it into my phone. When I went to the Music Player, it showed that there was nothing on it. So I plugged it back in the computer. It still showed that the music was on there. Just to make sure that it wasn't the whole SD, I decided to put some photos on the SD. When I plugged it into the phone, all of the pictures showed up but none of the sings did. Any advice?
  • Bcckitty Dec 29, 2008
    ACtually the whole thing went blank. SO i bought a different one. THanks for trying to help though.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What format are the music files in?
chuck starck
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 21, 2017
chuck starck
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
5876
Points
23
Files must have the correct extension. i.e. .wav or .mp3 or whatever the music player requires. You may need to convert the sound file to a different type for the device to see it. It may show in one device and not another for this reason
5 Related Answers
Anonymous
  • 41 Answers
  • Posted on May 24, 2008
SOURCE: Hi ya doin?
Put it into your computer, go to Start>My Computer. Find your card, right click it and somewhere on the list there should be a format option.
Anonymous
  • 10 Answers
  • Posted on Jun 26, 2009
SOURCE: Pny micro sd won't copy files
has the write protect been moved
Anonymous
  • Posted on Sep 26, 2009
SOURCE: I have a PNY MICRO SD 2GB for my Samsung Messenger.
Hi. Well the problem is that your songs probably aren't recognized as mp3 files. I have a SanDisk micro SD and I downloaded a CD onto on a program such as RealPlayer or Windows Media Player first. Secondly, I dragged the files from there onto my SD. Try this but if this doesn't work then take out your micro SD and format it to your phone. This will end up erasing all that you have on there and possibly require you to do it many times just as I had to do, t eventually mine did work perfectly. I hope this works.
Anonymous
  • 50 Answers
  • Posted on Jul 05, 2010
SOURCE: my pny 2gb micro sd memory card is
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk Management. Select the micro SD drive and click Delete. Right-click on empty drive and select New Partition.
Anonymous
  • Posted on Oct 21, 2010
SOURCE: My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
2answers
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
How do i hook my PNY micro sd to my computer
check if the lock tab on the adapter isnt on lock
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Getting music onto my pny micro sd 2gb
You should just have to locate it in "my computer" open it up and drag and drop music files onto it. or just burn them on to it. e.g windows media player. if it wont let you. make sure its not locked by checking the switch on the side. Also ask your friend if he set a pin/password for this micro sd.
I have a PNY MICRO SD 2GB for my Samsung Messenger. When I put the Adapter into the computer it showed some files. One named My_Music. I put a CD in and downloaded the Cd onto the My_Music file. It showed...
Saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Top PNY Electronics - Others Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
