Question about Bose Lifestyle 18 System
No sound from my bose lifestyle 18 system
In my bose lifestyle 18 system when I play DVD I can see the video but no sound at all,need help on what to do
  • Anonymous Dec 28, 2008
    have the same problem. I checked all wiring connections, but same results.
    New Friend:
  • 111 Answers
CHECK THE SOUND SYSTEM ARE YOU SELECTED FROM AUDIO SETUP CONFIGARATION.
CHECK THE MUTING STATUS.
BEST REGARDS NUWAN.
Posted on Jan 09, 2009
My bose lifestyle 48 say resolutio not supported when i try to play a dvd but i have sound without a picture. how can this be fixed
Is it a copied DVD or DVD-R / RW? If if says resolution not supported then it means that the DVD has a video format that cannot be played on the Bose even though the sound track is fine. The DVD may work fine on a PC as these can usually play more file types, but it could be a number of things causing it not to work and unfortunatetly there is nothing you can do.
Jun 29, 2014 | Bose Lifestyle 48 System
My lifestyle 18 displays "reading disc" when a DVD is inserted but will not play the disc. I have no problems playing music CDS on the system. Any suggestions?
Buy a computer DVD drive and replace the one in the unit. They cost about $30. It needs to be an IDE drive, not a SATA one.
Jul 06, 2010 | Bose Lifestyle 18 System
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
Cable Guy messed up Bose 18 sound
Make cable guy get you one.I cant believe he left without fixing it.
Sep 20, 2009 | Bose Lifestyle 18 System
Can't get sound on tv but dvd and radio work.
Sounds like an install problem. All of your inputs (audio and video) should run through the BOSE and then only the video out needs to run to the TV. In this way the BOSE is the sound source for everything
Aug 30, 2009 | Bose Lifestyle 48 System
Bose lifestyles v28 plays dvds in black and white
Check your video output settings in the menu. If you are using a composite video output and do not have the system sut up for it, you will get a B&W picture. Check your menu settings.
Aug 19, 2009 | Bose Lifestyle 28 System
DOES NOT RECOGNISE CERTAIN VIDEO ON DVD
there are programs out there on the web on how to convert those files avi and dvix to mpeg. there are some free software but the better ones cost some money. i reomend doing some research first on these differsnt programs....try cnet
Mar 12, 2009 | Bose Lifestyle 18 System
Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Jan 31, 2009 | Bose Lifestyle 18 System
DVD player will not open
Hi, I think the DVD disc was not positioned properly (since yo udid mention that the disc did not play) adn that it has jammed the tray. Please avoid furtherusing the unit as this may damage the eject gear mechanism. Only recommendation is to bring the unit for service and they can physically rmeove the jammed disc.
Aug 09, 2008 | Bose Lifestyle 18 System
Bose Lifestyle 18 System Logo
427 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
