Question about HP Deskjet D4160 InkJet Photo Printer
Unable to print with new ink carts
I had both black and color ink cartridges refilled at walgreens. now, my computer says that there is a problem with the color cartridge and it won't print. walgreens assured me that this ink was compatible with my printer. they both seem to fit fine,( they are the original cartridges, or so i thought) thanks
  • 232 Answers
Usually, that message means that your cartridge is dead. Try removing it, clean the electric contacts on it and the ones on the cartridge carrier. Put it back in. If that doesn't help, you will need to buy a new color cartridge.
If you do not have a replacement cartridge, you can still print in, what HP calls "ink backup mode". Simply remove the problem cartridge, and print with the remaining one, in this case, the black one.
  • If you remove the tri-color cartridge, printouts will be in grayscale.
Posted on Apr 14, 2010
Installed new blk ink cart and others are all o.k. Will not print black at all - if I use the color button or try to print from the computer in color, words come out very light and other colors are not...
I assume that you inserted an new OEM black cartridge. If you are using aftermarket of refilled cartidges, change to an OEM cartridge.
- Press on the printer
- Press of and select
- Press of to choose , or
- Press
- The machine cleans the printerhead and goes back to the Ready screen when finished.
If you clean the head 5 times and things don't improve, the printer should be serviced at a printer service center.
If you are using aftermarket or refilled cartridges the ink is typically not up to manufacter specifications and can gum up the printheads.
Oct 04, 2010 | Brother Office Equipment & Supplies
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
I replaced a new lexmark 23 print cartridge in my X4530 printer.
This happens from time to time. I have bought new 22 & 23 cartridges for my Lex. x3350 before with "flawed" contacts. Either return it for refund or buy a new one. Thw next working one you get, try re filling it. I get mine refilled at Walgreens. Cost for me in Texas is $10 for black and 15 for color. I refill them 4 times before I replace with new. Saved me a ton of money.
Jul 01, 2009 | Lexmark X4530 InkJet Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Refilling lexmark cartridges x2500
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
Color ink cartridge
Yes you need to have both carts in the printer
Jun 02, 2008 | Lexmark X2500 All-In-One Printer
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
HP Deskjet D4160 InkJet Photo Printer Logo
234 people viewed this question
Ben Johnson
