SOURCE: '06 Harley Davidson FXDI35 Speedometer and Accessories Don't Work
Check for coroson on all the conectors.
SOURCE: turn signals stopped working
I may have had the same problem. Last summer I fnd at times my Headlight would intermittently go out usually after riding over a bump or just after starting the enging. I later found that the starter button was jiggling around inside its recess making intitial contact with the posts causing the headlights to go (as they should when normally starting the engine). To check, pull the start button out while it's running and check the operation of all the lights.
SOURCE: lights, turn signals, horn don't work
Look for a bad ground connection inside the headlight shell (or possibly elsewhere). The other thing that all of the items you mention that are working intermittently have in common is the ignition switch. With the switch 'on', check for battery voltage at the fuses for the headlight, turn signals, horn, etc. No voltage at the fuses likely means a bad ignition switch.
Testimonial: "quick response to my posted problem. don't know yet if that's the problem, but i've got a good place to start looking. thanks for the help."
SOURCE: I have replaced the stock tail light assembly with
i dont know alot about this but my best gess is you have a bad ground check and make sure you have a good solid connection. hope this helps you.
