Question about Canon imageRUNNER 8500 Copier
Error code E000732-0001 Imagerunner 8500
I have this problem when i make a bunch of copies, so i have to turn off then on the copier, to be able to continue working, i need to solve this problem, Tahnk you
    President:
  • Canon Master
  • 990 Answers
Dear sir;The error code you submit its means " main controller board " have problem, but don't worry let's try to reset it just follow the steps;
1, select service mode @ for service additional functions key.
2, press "*" key, 3, press "2" & "8" at the same time.
4, press "*", 5, press "copier" then press "function" then press "clear", then press "err" final press "OK"
6, turn power off and back on again. your machine should on working condition, If not please let me know, otherwise be generous rating me. thank you,
HAVE A MERRY CHRISTMAS !!!
Posted on Dec 23, 2008
  • 168 Answers
This is a reader controller error replug all connectors in the back also when you say make a bunch that that mean alot scanned in if so you might want to see if your optics need to be cleaned
  • andzulisv Dec 24, 2008
    that reply about the clearing the code using service mode does not apply this code.
Ir 85 error code E000015-0000
hello
8500 IR copy machine
E00015 - 0000 errors.
Please guide me.
I also translated by the site you have to translate the sentences. So you have the goodness wording is easy.
Thanks
Nov 19, 2012 | Canon imageRUNNER 8500 Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
What is error code E000001-0004 and E000001-0010 for canon copier 8500
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
May 19, 2010 | Canon imageRUNNER 8500 Copier
Error Code 00510 Canon 8500 What is it?
pls check yr saddle finisher.[ feed motor]
Mar 04, 2010 | Canon imageRUNNER 8500 Copier
This error code is a sensor in the side where paper jams usually occur open the door and look for a small sensor in black plastic, it will probably be not located properly these are known for dislodeging, Canon engineers simply glue them back in, switch off the power beofre doing this and when you switch back on it should load ok.
Feb 23, 2010 | Canon imageRUNNER 8500 Copier
ERROR IN IR 8500
eo 732 is a reader board error or a bad or missing connector from the scanner to the machine looks like a parrallel connector
Dec 25, 2008 | Canon imageRUNNER 8500 Copier
Error code E000732-0001Imagrunner 8500
that's reader controller board or main controller board, may send back to repair.
Dec 15, 2008 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 8500 Copier Logo
1,217 people viewed this question
old marine
old marine
