Question about Carrier 38CKC042 Air Conditioner
Noisy furnace Sounds like the blower might be making noise. Is there a way to lube the blower? A service manual would be a great deal of help to me. The unit is a Carrier Model 58RAV095-16 Series 161 S/n 2097A12945 At times it seems there is a humming coming from the furnace and no air from the vents, this happens after unit is on for a period of time. Thanks for any info.
  • wemoseley Dec 24, 2008
    Is there a parts manual that I can get p/n's from? I am able to replace this myself. I just need more info to go on. Thanks
    President:
  • 2,110 Answers
  • 15,935 Answers
    Top Expert:
  • Carrier Master
  • 78,267 Answers
The most common cause of noise is the blower motor bearings they are sealed, so replacement is the only option.
Posted on Dec 23, 2008
Is it cost effective to replace draft inducer blower on 22 year old furnace?
Depends on the cost to repair. Probably a 22 year old furnace is not very efficient also. Take every thing into consideration.
If it still works it may work for a while but you don't want a break down in the middle of winter.
Nov 07, 2014 | Heating & Cooling
I have an older Miller Furnace in a mobile home that I own. The unit was made around 1977-78. Think the model number is MGC-80-1. It does two things that seem odd. 1st is it will kick on like it should,...
sounds like the fan control is playing up try cleaning the back of it could have dust in it cleaning my help fan could be a loose spindal which the fan spins on see if this helps
Nov 06, 2010 | Heating & Cooling
It's a brand new unit but it blows air so hard and makes so much noise. Can the flow the adjusted down?
is the fan outside too noisy,if so there is no way to change the speed of this fan,the blower motor in the furnace can be adjusted,either by adjusting the centrifugal pulley on the motor shaft or electrically or installing a different squirrel cage fan on the furnace blower
Aug 22, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a magic chef ultra 97 furnace. the blower started making a noise. i removed the blower and blowed the blower out with air and lubed the back bearing with pb blaster. reinstalled blower. the blower...
u may have a bad ignitor or u might not have hooked up a safety switch or u may have accidentally caused a sensor to go out not knowing but it sounds like the ignitor is bad is it a glow plug or does it spark to light
Feb 26, 2010 | Heating & Cooling
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Carrier 58mvp furnace ecm motor is making viberating noises
ecms are pretty reliable and electronic failure is much more common than bearing or bushing wearout. i suspect the fins on the blower may be coming loose from their pressed on spline and that will start a vibration or shimmy or you could have thrown a weight that balanced the wheel . best to use to warranty to get a new wheel. good luck
Dec 07, 2008 | Carrier 38CKC036 Air Conditioner
Noisy air conditioner
Sounds like the motor shaft and/or blower wheel have broke. The best scenario is that the blower wheel has only become loose. Shut the unit off. If you are comfortable using tools then use your manual to show you how to remove the blower assembly. When it is out you will need to check the Allen screw that holds the wheel to the motor shaft. If you are lucky you can just align the screw with the flat side of the shaft and re tighten! If you have the unit out, it should be pretty obvious if there is any other physical damage. Make sure you can spin the unit freely without any other complications before re installing it. Good Luck!
Jun 27, 2008 | Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
88 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
