Question about QMark MUH (0521) Compact Heater
QMark MUH heater makes metal rubbing noise when on.
The heater is hard mounted to the circuit. No chorded connection.It makes a loud metal scratching noise when it comes on. The product still heats up the garage but the noise is very loud and I am worried that it may start a fire or blow the breaker.
2 Suggested Answers
mike17757
  • 10 Answers
SOURCE: My Qmark electic heater keep tripping the breaker
You will need to provide additional diagnostic information. Most likely the breaker is defective. Warning: potential for injury is HIGH working on power electrical! Do not attempt if you do not have experience and training. Proper personal protective equipment and methods should be used. The running amps needs to be measured when the heater is turned on. Find the rating on the breaker and calculate 80% of this rating. The heater current should be less than this value. If the breaker is tripping when less than 80% is measured it is most likely defective. Measure all power legs on the heater. Also check the nameplate info on the heater Volts, Amps. Compare these values to the actual.
Posted on Feb 06, 2015
Why doesn't it heat?
either the heating coil is broken or sensor is bad, buy a new one it is cheaper then trying to have it fixed
Dec 12, 2015 | QMark MUH (0521) Compact Heater
Fan runs, but why no heat coming out of unit?
element is not working
elementary isn't it watson?
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
Qmark muh won't shut off
I believe these models have a thermal switch on or near the heating element that normally runs the fan until the element has cooled. Similar to your home furnace. If the fan never shuts off this switch is likely bad. IF it takes a long time to shut off then it may be out of calibration. In either case they are non repairable parts and have to be replaced. If the heater is in a high spot resulting in a high ambient temperature it may take a while for the fan to shut down.
Dec 20, 2011 | QMark MUH (0521) Compact Heater
Muh108 single phase what size breaker to use 40 or 50 amp
IF it is 10KW at 208 single phase it should be on a 60 Amp breaker.
3 Phase would be 35 Amps. Always check the nameplate for additional information. It may be configurable for different voltages. Best to check manufacturers data if available.
Mar 05, 2011 | QMark MUH-35 Heater
QMark MUH-35 Heater (elec. garage heater) how to reset the Thermo. runs all the time,garage is warm.
If you cannot regulate the heater at all and the unit runs all the time no matter what you do, the thermostat or fan switch may be faulty and require replacement.
Here's a web site for this heater from which you may be able to obtain parts and/or further information:
http://www.heatersplus.com/muh-35.htm
Jan 04, 2010 | Kitchen Appliances - Others
INNEED OF PARTS
There isa co. called "grainger" that can get any parts you want..not need!
Dec 21, 2009 | QMark MUH-35 Heater
Muh -07-4 480 volt heater
no, you need to rewire the motor.
the heater elements may not let you do that, since it is rated for 480v.
Dec 02, 2008 | QMark MUH-35 Heater
QMark MUH (0521) Compact Heater Logo
114 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
john h
Danny Kuhlmann
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
