Question about Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan
Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
The fan assembly is starting to really vibrate. I do not see a way to get at the motor and bearings for replacement without just replacing the entire unit which is mounted to a Ceiling joist in the attic. The support bar that the fan motor is screwed to is not removable. It appears to be pressed or riveted into the fan housing. Is there some trick to removing the motor from inside the bathroom?
  • ekissner Mar 21, 2009
    Isn't there a way to spray wd 40 on it?
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Posted on Feb 02, 2009
  • 37 Answers
There usually is a way to pry out the motor (and bracket that it is attached to) from inside the bathroom. If you take the grill off and the light most of what you see is the bracket that the motor is attached to. look for a small screw along one edge or a small flange that is inserted into a slot in the actual housing. sometimes a straight screwdriver is necessary to pop it out. Most fan rattling, however, seems to come from either a blocked duct, or that the whole fan housing is loose somehow. Check that also.
Posted on Jan 29, 2009
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
Is there a quieter, alternative motor that can be installed in a NuTone 763RLN bathroom fan?
I just installed one of these; the directions were not really helpful, and I'm fairly handy doing these things. Anyway, the 'specs' say this is 2 sones, and mine is pretty quiet. I did have to tighten the acorn nut that is under the light bulb, that holds the light fixture to the rest of the unit pretty tight. My noise was coming from vibration, not the fan 'noise'.
Jun 25, 2012 | Broan-NuTone N-763RLN Combination Light...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
I need an exploded picturial view of the BROAN fan and light kit. Thanks
go to www.broan.com from there you can look up that fan/light combo and download the installation manual which will give you the exploded view.
Broan Bathroom Fan Care and Cleaning
heatman101
Jul 02, 2009 | Broan-NuTone N-8663RP Combination Light...
Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Replace exhaust fan with fan & light?
sure just hook them both together, you wont be able to switch one off with out the other being switched off.
Dec 10, 2007 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
1,073 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
