Question about Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch SHU5300 When I run a cycle the machine counts down until it gets to about 9-15 minutes. Then it pops back to the 45-55 minute and continues to do this. I tried on all cycles. One the regular cycle it stayed on 1 minute forever and I had to manually drain and stop. It will never get into the rinse and heating cycle. The rinse and hold works fine. Any suggestions. I really like my dishwasher. It is just over 5 years old and is the best dishwasher I have ever had for cleaning and almost no noise. I hate to have to think of getting a different one as I like this one so much. Any suggestions. My thoughts are either a heating element gone bad or the electronic cycle board. Anyone - please help. Thanks. Mary
  • 2 more comments
  • skinonna Nov 15, 2007
    I have the same problem and have lived with it for 2 years because it sort of works........Sometimes there is no problem. The hold on 1 minute is the most frequently occurring event. Change the board...I'm married to Mr. Fixit, everything but electronics that is. But if it is a plug in board that's not a problem. Can you give me a little walk through.
  • kevlar7 Aug 16, 2008
    Dishwasher ran for 4 hours. I am not aware of a pattern as described in the other posts but it runs on and on. Where can I find a board and how would I put it in?
  • Anonymous Sep 13, 2008
    just gets stuck on one ALL THE TIME!!
  • finley344 Feb 04, 2009
    The countdown timer stops at 1 minute and stays there until I cancel out and the thing drains. However, this doesn't allow for drying the dishes. What exactly needs replacement?
If your heat cycle is not coming on, which it sounds like it is not, then you may have a problem with the heating system. There is a well known issue with many of the Bosch dishwashers that use the (266746) control module. Basically, there is a relay (which is a kind of electro-mechanical switch) that is used to turn on the built-in heater. There is a solder joint on the main Printer Circuit Board (PCB) that allow electricity to flow to the heater, that joint often will melt away and burn the surrounding area of the PCB. This is most likely a design flaw and appears to occur at about the 4-5 year mark. One way you can test for this is to run the onboard diagnostics routine that is programmed into the firmware of the micro-controller (brain) of the dishwasher. The way to do so it to press and hold the (Scrub Wash & Delicate/Econo) buttons at he same time and then press the on/off power switch to the on position. The LED lights above both those buttons should begin to flash, when they do, press them both again and the diagnostics program will start. It is a multi-phase program that will run for quite a while. Once it finishes, if it is a heating problem, it will end with a number 2 code in the display. If this is so, then it very well maybe the solder-joint issue on the control module and it will need to be replaced. It runs $128.10 US directly from www.bosch-appliances.com. Good luck.
Posted on Jun 30, 2009
    Problem Solver:
  • 14 Answers
You need to change the board . I can help you check the board if you would like
Posted on Jul 08, 2007
If the circuit board trace has overheated and burned through, is it possible to solder a solid wire (of heavier gauge than the original trace) to fix the problem?
Posted on Dec 10, 2009
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
My bosch dishwasher counts down to 1 minute on any cycle but will not drain except by manually hitting cancel. I've replaced a defective drain pump but it still does this- any ideas?
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 18, 2013 | Bosch Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Bosch she44c wash cycle time keeps extending. Once averaged about 130 minutes, now starts at about 150 minutes indicated. Seems to hang up at 1 or 2 minutes before cycle end, then keep running for as much...
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
Sep 27, 2009 | Bosch Dishwashers
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Apr 14, 2006 | Bosch SHU5316UC Dishwasher
Bosch 23 in. SHU5302UC Built-in Dishwasher Logo
1,018 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
