Question about Maytag MER6769 Gemini Electric Kitchen Range
F9 on Maytag range MGS5770ADB
Had an error on F9 on Maytag range model no. MG5770ADB
Ordered a new clock an microprocessor board still has same problem error F9.
Can you help me
    President:
  • 2,110 Answers
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Posted on Dec 23, 2008
    Guru:
  • 558 Answers
Thanks for your posting in FixYa.
Sorry I am unable to locate your Model.
Do you have Drop-In, Freestanding, or Slide-In Maytag Range??
I will get you soon to fix the problem. Please reply me back with more detail.
  • Puneet Jain
    Puneet Jain Dec 23, 2008
    For F9 possible resolution can be applied on Maytag Oven:
    The Bake or Lock icon may flash rapidly in the display to alert you if there is an error or a problem.
    If the Bake or Lock icon flashes in the display, press the Cancel
    pad. If the Bake or Lock icon continues to flash, disconnect power to
    the appliance.
    Wait a few minutes, and then reconnect power. If the icon flashing
    still continues, disconnect power to the appliance and call an
    authorized service Station.
    Best of Luck & Merry Christmas,
    Scott
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, to my knowledge, an "F9" error indicates a door lock problem. Might it be the problem is the switch/sensor that detects if the door is fully closed and latched?
Good luck and Thank you for using FixYa. Happy Holidays.
F9 error after power glitch
F9 is a door latch problem. its saying it can not read or detect if door is open. repair latch. good-day ! Unlock door and inspect the switches or clock assembly.
Nov 27, 2011 | Maytag MER5770 Electric Kitchen Range
What is an F8 error code meaning? Thanks!
From this website ::
http://www.ehow.com/facts_7597003_maytag-range-error-codes.html
Codes "F0," "F1," "F5," "F6," "F7," "F8" and "F9" are all various errors with the Maytag electronic range control, or ERC. The errors are various faults with the ERC and a replacement part is needed for the range.
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) More info, let me know. Charlie
Jul 26, 2011 | Maytag MER5775Q Electric Kitchen Range
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
Jan 16, 2018 | Maytag MEW5530D Electric Single Oven
Error code f9 is telling me what
Hi, F9 indicates a door lock problem. If no problems are found with the latch mechanism you will need to replace the ERC/clock module. For diagrams and illustrations enter your model # at
appliancehelponline.com All parts come with installation instructions.
Thanks for using fixya....
And please don't forget to rate me..
Oct 28, 2010 | Maytag MER5775Q Electric Kitchen Range
F9 Error- the lock for the self-clean cycle accidently was pushed in the lock position without having the door closed
Hi
Thanks for using FixYa.
F9 error in your Maytag indicates Door latch issue and to resolve this you'll have to check the door lock circuit. If that is fine then replace the clock assembly/Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Maytag Kitchen Ranges
I have a Maytag super capacity range and I am getting an F9 error message on the display. I can't find the model number and it is not where maytay said it would be on the range (according to the site)
The F9 fault code means door latch problem. Check door latch hardware. Here is a list of the Code Description for your unit. Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. DON'T FORGET TO RATE THIS POST!!
Sep 18, 2010 | Maytag Kitchen Ranges
Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Jan 18, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
F9 error message - what does it mean and how can I fix?
If the heading you used is correct and this is a Maytag Kitchen Range, "F9" is a Door Latch Supervisory error, or a defective Electronic Range Control (ERC) board (this is the clock assembly board). Since you mentioned you are having difficulty with the door latch mechanism, I would attempt to repair or replace it first. The door latch costs around $50, while the ERC runs about $140-$150 @ repairclinic.com. Just type in your COMPLETE model number in the Search menu and there's a complete parts listing available with illustrations. They also have a service manual available (item# 893398) for about $30 that you can order to assist in repairs. Post back if you need further assistance, please. I hope this helps you.
Mar 27, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag MER6769 Gemini Electric Kitchen Range Logo
639 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
