Question about Kenmore 43142 Front Load Washer
What does F- indicate?
Yesterday while doing load, 3/4 full, with recommended amount of soap the washer stopped had burning smell, time window said 5d or Sd. Today tried to run a water load, no clothes no soap. It stopped for about 10 minutes with the code 5d or Sd. It started running on its own. No it stopped and the code is F-. Any ideas? I use HE soap and always the recommended amount. Thanks C. Paul
  •  Sherman
    Sherman May 11, 2010
    there should be a number after the F. do you know what it is
    Scholar:
  • 31 Answers
The SD code, is a sudsing code. If you are using the appropriate amount of soap and HE soap, it could be a communication error with the sensor and the CCU (the main control board). If you take off the panel on the bottom of the front (3 screws on the bottom hold it on). Once you get in, there is a plastic pouch on the right hand side there is a tech sheet that will have a list of all the error codes, and what to check.
Good luck
Posted on Feb 12, 2009
Top loader smells like wirers burning and squealing when spin cycle starts
Hey Tara, I understand that your Frigidaire Top Load Washer is squealing and presenting a burning smell. Is this occurring every time you are using the washer or with random loads? Typically, when you experience the squealing and burning smell it indicates that the washer is possibly overloaded. I would recommend that you stop the washer and reduce the load. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 27, 2015 | Washing Machines
I have showing 5d does not spin what does it mean
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Jan 04, 2015 | Kenmore Washing Machines
How do I clean my front load washer. the clothes are starting to smell musky
Try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell.
Thank you
Jul 03, 2010 | LG WM-2277HW Front Load Washer
My lg washer was working and suddenly a burning smell came out of it and we dont know how to make it work again
Thank you
Jun 07, 2010 | LG WM1814CW Front Load Washer
Everytime we do laundry, we have a horrible smell in the washing machine. We have tried bleach and hot water but no success. Any other ideas?
Be sure your using HE Laundry det. only use the recommended amount on the bottle, I use the liquid, the less the better, I use the least amount.....To much soap left in clothes can cause mildew and stinky smell, also I recommend using a fabric softner, it helps to remove the soap....and smells good....also use a good washer cleaner, I use Affresh, they come in tablets, go to www.affresh.com and put in you zipcode to find where you can purchase it in you area......make sure after a load is finished that it doesn't sit in the tub with the lid down for long, removing the laundry promptly will also help with stinky laundry........also, leave the lid or door open for a couple of days to air it out after cleaning.....use the Affresh at least once a month.......hope this helps you
Jan 08, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Error code 5d?
Hi
This is actually a SD code meaning to many suds. The machine will drain out mid-cycle when you push stop. You can then start the load over without adding any additional soap. Make sure you use the recommended amount of HE soap.
thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I keep getting a 5d error code on my machine. What is this?
Mar 02, 2009 | Kenmore HE2 Plus Front Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap left in clothes
hope you are using he detergents (high effeciency low suds) also if you have soft water oversudsing can occur even with he ..try reducing amount ..also have been told tide he detergent tends to suds more so may try switching detergent brands try runing washer with no soap no clothes begore next load to flush out any detergent that may remain ..be sure to run washer with bleach no clothes on short cycle peroidically to avoid mold/mildew odors that front loads tend to acquire after a few months use and leave door open if possible between uses..let me know about detergent thanks
Jul 15, 2008 | Kenmore 44102 Front Load Washer
This code keeps coming up on my washer
Thanks, wilbur 24 for the input.
If this is a Suds error, then you will need to run the washer on a Rinse & Spin cycle with no detergent added to get rid of any excess soap. NOTE: You may have to repeat this cycle several times in order to clear the error.
Are you currently using HE detergent? If not, it is strongly recommended that you do. HE rated washers are supposed to use HE detergents because they are formulated for wash tubs that only use 5-7 gallons of water (like yours). If you use regular detergents you are, in affect, adding a higher concentration of soap that is formulated for wash tubs that have a 35 gallon capacity. This can cause damage to the tub and pump seals. Most manufacturers now have a disclaimer that states that the warranty becomes null and void if it is doscovered that you have used the wrong detergent.
In addition, some HE detergents are DOUBLE-CONCENTRATED, which means you only use HALF the amount you normally use. Make sure you read the label carefully to ensure you aren't inadvertently adding too much detergent.
Some other things that can cause over-sudsing include washing too little clothing with too much soap and soft water. Its best to wash full loads with front loaders as they are rated for large capacities. Cut back on the amount of detergent when washing smaller loads. Soft water can make detergents work better and create excessive suds. Try using less detergent.
I hope I don't insult your intelligence. I'm just trying to give you some sound advice in the event that you are not aware of some of the common causes of this problem. I hope this helps you.
Mar 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 43142 Front Load Washer Logo
152 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
