Question about Amana ACF3325 Gas Kitchen Range
Amana inside oven light not working.
My "Big Oven" Amana oven inside light stopped working. I have a new bulb, still no light. Is the problem withthe switch or something else
  • 1,031 Answers
Check the socket assembly.remember Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. ! check the switch Usually the switch will be either on the control panel or inset into the oven door opening. Now you need to gain access to the back of the switch in order to test it. Check your range's operating manual for access and mounting details. Most switches are push-in types, and you can carefully pry them out from their location with a thin-bladed screwdriver.
  1. Once you have gained access to the switch, label and disconnect the wires from the switch's terminals Set your VOM to ohmmeter function and set the range to R X 1. Touch a test lead to each of the two terminals on the switch.
  2. If the contacts of the switch do not make contact in either on or off positions, there will be no continuity in either position. If the switch is shorted, there will be continuity in both positions. In both cases, the switch is defective and must be replaced.
  3. Carefully replace the wires to the correct terminals of the new switch. Now install the new switch in its mounting position. hope this helps. pls appreciate by rating as fixyaa
Posted on Dec 23, 2008
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
I have an Amana Big Oven. Oven light will not work and I installed new bulb.
LIKELY the switch in the door jam bad or sticking or a circuit problem like a broken wire.
Nov 06, 2012 | Microwave Ovens
Gas oven bulb hanging inside + can i safely use this oven?
Sparks ignite gas. Sparks are usually present when switches are turned on and off (usually at the switch - not at the bulb).
Don't turn the light on/off while you are trying to turn on the oven. Once lit, the light can be turned on and off without fear of an explosion.
The big issue is melting the wires near the base of the bulb when the oven is hot. Get it fixed.
Mar 20, 2010 | Ovens
Light will not shut off
The only thing thing it can be is the light switch, as this is what gives the power to the light bulb.
It sounds like the switch contacts have shorted, thus giving a constant feed to the bulb, If it were me,I would fit a new switch, but to be sure, pull the leads of the switch, and the light should not work.
MAKE SURE POWER IS OFF FIRST!!!!!.
Feb 08, 2010 | Amana AOCS3040SS Electric Single Oven
How do I change the light bulb in the amana range
You change from inside of oven. Bulb will be located under glass bulb cover. Push clip to side, remove glass cover, then unscrew bulb.
Jun 16, 2009 | Amana ACF3325 Gas Kitchen Range
Replace microwave light bulb
See page 24 of the owner's manual here:
Feb 06, 2009 | Amana AMV5206 Microwave Oven
Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
Dec 01, 2008 | Amana Radarange Microwave Oven
Amana AM6177 Microwave
Interior light bulb is located behind the grill, above door. It requires removing 3 or 4 screws to remove grill. I have same problem. I pulled out bulb, it looks like it was glued in some type of foam material. There are two pin connectors at the mounting. but I can't see how they fit into bulb.
Apr 07, 2008 | Amana AMV6177 Convection/Microwave Oven
Oven light problem
sure you can use with out back cover, sounds as if connection inside socket is loose( not making contact with bottom of light bulb securely
Feb 10, 2008 | Whirlpool RF368 Electric Kitchen Range
Broken Oven Light
I would look at the switch as the problem for this. Either the one on the door, or the one you turn on yourself.
Jan 13, 2008 | Kitchen Ranges
Open Questions:
Amana ACF3325 Gas Kitchen Range Logo
564 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
