Hi, After plugging it in, the TV comes on for a second, then goes off. The red light blinks 1 second the is off for 2 seconds and repeats cycle.
SOURCE: My Sony KDF-E60A20 loses audio and video in a cyclical manner
Unfortunately, what you're describing is a repair issue. You won't be
able to address the problem with troubleshooting. There is a part
inside the TV that needs to be replaced. If you're under warranty,
this will cost you nothing. If you're not under warranty the cost
will likely be a minimum of $200 parts and labor. However, be warned
that the cost could be considerably higher. You should call the
manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: 14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
SOURCE: TV turns off/on
I had the same problem on my TV (had it for 2.5 years) tried to clean the bulb, but it still did the same thing. So i replaced the blub and the problem went away and the screen is brighter now. Sometimes it just about that time to replace the blub anyways.
SOURCE: Good afternoon, Sirs! I bought an
Hello AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with
Blinking of standby light is Sony TVs are fault indication. Five blinks denotes
the video. You must have some knoledge in electronics and ability to follow the schematic diagram of TV otherwise called as circuit. Must have a high quality digital multimeter, soldering iron and a concept of soldering. I'll assist you. Must have confidence and more patience. If you have these, inform me by Fixya. I'm happy to assist you. If not, get it repaired by Sony Authorised service center. Any service center, who takes this set for repair, must have all the testing equipemets like oscilloscopes, clour analiser, pattern generator and AVO meter. Without these testing equpments, trying to repair this set will make things mor worse. OK.
SOURCE: Sony LCD TV Model #KLV-23HR2 The timer LED
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
