Question about Intel D850MV Motherboard
Memory Sticks. Im confused on what memory sticks to get, For memory type is says "RDRAM(RAMBUS)" Number of memory slots is says "4x168 Pin SDRAM DIMMs" Do i get RDRAM? Everywhere says all the RDRAM is 184 Pin..Im confused. Can SDRAM fit? As of now there's 2x128mb in there, with 2 other things filling the other 2 slots, what are they? can someone help?
  • Janusz Nov 09, 2007
    hi ,
    the quastion is:
    1. can I use both  Non ECC and ECC RDRAM memory modules, one of them in bank 0 and next in bank 1
    2. Can I use both RDRAM PC 800-45 and PC800-40
    in my Intel D850MV motherboard ?
    WIN XP Home
    my e-mail: janusz789@interia.pl
    Problem Solver:
  • 9 Answers
Do i get RDRAM? yes, and never mix your memory. Use Supports fast PC800, PC600 RDRAM* memory from 128MB to 2GB. Question: As of now there's 2x128mb in there, with 2 other things filling the other 2 slots, what are they? Answer: These are dummy memory sticks u may remove these to add more memory sticks. You can use 128MB x4 or 512MB X4 (PC600/800 RDRAM) Best bet is 512MB X4
Posted on Apr 11, 2007
    President:
  • 2,961 Answers
No you cannot fit sdram, they will not fit. Go to the link below and it will explain what memory you have and if you use the pc to go to thie link there is a memory advisor tool to the right of the page which will search your pc and advise you as to what upgrade you can have. http://www.crucial.com/library/ddr_vs_rdram.asp
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
I have a HP a1514n media system with 2 - 512 sticks of ram. I replaced one of the 512's with a 1GB stick and my system only shows 1024 ram available. I checked the settings in startup and it shows...
First of all, make sure you have the right memory - 240 pin, DDR2 SDRAM, PC2-4200 MB/sec.
Your machine should support the memory as it has two banks of 1. Sometimes it is simply a sequence problem. In older machines with mixed memory, I always put the largest and fastest in the first slot. You might try just reversing the memory.
Jul 19, 2011 | HP Pavilion a1514n (EX269AAR) PC Desktop
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
May 15, 2011 | Dell Precision 530 PC Desktop
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
I just need to upgrade the memory on a Dell Precision 530MT.. can't seem to find the exact type of memory it needs.. any ideas?
HELLO Paul
When installing memory modules in the system board sockets and not using the optional memory riser boards, observe the following guidelines:
  • Each memory socket on the system board must be occupied either by a RIMM or a CRIMM.
  • Memory sockets must be upgraded in matched pairs. In other words, two sockets in a pair must contain modules of identical capacity, number of components, and speed. See "System Board Memory Components" to identify pairs of sockets.
  • Mixed pairs of ECC and non-ECC modules all function as non-ECC.
  • Be sure to install a RIMM in socket 1 first (closest to the processor) before installing modules in the other sockets.
  • The system board supports PC600 and PC800 memory modules.
  • http://www.memoryx.net/precwor530.html what memory part numbers you should buy and cost
the link below will give you what type of memory you need to isntall
http://support.dell.com/support/edocs/systems/ws530/en/sm/2memory.htm#1149832
please rate my service
Nov 19, 2010 | Dell Precision 530MT (WHL530MTGHEI31LE) PC...
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
I have just installed more memory to my computer and do not notice any difference in the speed of my computer
you may have installed memory that may not be compatible with your motherboard
do you know what type of mother board you have..
your memory must match in this categories
1. type (ddr, ddr2, sdram, simm, rimm)
2. speed (measured in mhz or sometimes given as a pcXXXX number)
3. cas number.
4. whether is ECC, parity, buffered, registered, non ecc
5. check your motherboard documentation to find exactly in what slot your new memory stick should go and which one should go first and which one should go second (ex. if you have dimm slots and you have 4 slots (2 pairs of different color) you may need to install one memory sticks like this: memory - empty - memory -empty
if one of the items that should be matched does not correspond your computer could work but it will work at the slower speed (ex. memory 1 (slow) + memory 2 (faster) = speed of memory 1
note: don't confuse memory capacity (1g, 512mb) with speed (333mhz, pc2700)... the best thing to do is to check the documentation of *********** board or even take the memory stick that you originally have and have the store looking for the memory that you need...
Sep 22, 2008 | Computers & Internet
Memory swap
This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
Jun 08, 2007 | ASUS P4S800D-X Motherboard
Intel D850MV Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
