Question about MSI KT4V (MS-6712) Motherboard
Unable to get 3GB of memory to work on the motherboard
I recently installed 3GB of memory on the motherboard, but it would not work. It did work with 2GB. I tried it with DDR 400Mhz, 333 Mhz, and even 266 Mhz, but with the same result. Could you please tell me what I need to do to get this working?
Thanks
    President:
  • 2,351 Answers
Hi enj1956, according to the manual the MB supports only,
"one" DIMM of DDR400MHz.
See page 2-7 in your manual.
You can use 3, PC2700/DDR333 / 3, PC2100/DDR266 or
3, PC1600/DDR200 to reach the 3GB.
All DIMMs must be the same memory type & speed.
MSI KT4V (MS-6712) link;
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=505
Good luck enj1956!
Any more questions?
Happy holidays!
Mike
Posted on Dec 24, 2008
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
I added 2x4G mem to the Asus M4N98, but the computer doesn't see it. Help?
Here is the memory spec for your board
4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*AMD AM3 100 and 200 series CPU support up to DDR3 1066MHz
**Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
***Refer to www.asus.com or the user manual for the Memory QVL (Qualified Vendors Lists)
Feb 11, 2011 | ASUS M4N98TD Socket AM3 Nforce 980a SLI...
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
VIA CPU to AGP Problem with 3Gb and Vista
Problem is you need to install Vista which support 4Gb! Look for specification on Vista you have!! Mostly XP and Vista support 2Gb!
The problem is in your OS. 32 OS support max 2Gb of ram they detect you 3gb but they couldn't operate with all!!
Jan 25, 2008 | MSI KT4V (MS-6712) Motherboard
MSI KT4V (MS-6712) Motherboard Logo
244 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
