Question about Sony VAIO FRV25 Notebook
Assembly Where can I finda manual to show me the steps in reassembling my sony laptop (pcgfrv25) after I replaced the dc power jack.
  • Sony Master
  • 4,806 Answers
Hi there
Its going to be trial end error from now on, there are no manuals for assembly at all i'm affraid
Good luck and kind regards
Posted on Dec 23, 2008
How to remove the bottom of a laptop to tighten the power supply outlet
You will probably have to strip it right down to get the motherboard out.
The socket might need resoldering. if you are not technically minded you would be better off taking it to a repair shop. You can do more damage than good if you are not careful. Youtube have a lot of videos about disassembling laptops / pc's if you want to do it yourself.
Feb 12, 2012 | HP Computers & Internet
Battery is showing 100 percent but you unplug power supply computer shut down also when you wiggle cord power shuts down
The DC jack in the computer has detached itself from the motherboard causing intermittent shutdowns, the laptop must be dis-assembled to re-solder the jack back in place, and may need to replace the DC jack if the old one is not suitable.
Feb 08, 2011 | Toshiba Satellite A105 Notebook
How do I replace the DC power Jack socket on my ACER Extensa 5620 .Mosel NO MS2205
Here is a place to buy a dc jack for the motherboard:
http://www.buy.com/prod/ac-dc-jack-power-port-connector-socket-for-acer-extensa-5220-5420-5620/q/sellerid/23962916/loc/101/215782024.html
This video will show you how to replace dc jacks in a laptop:
This page has the service manual for your laptop:
http://www.scribd.com/doc/13062016/Acer-Extensa-56206419-Service-Manual
Sep 22, 2010 | Computers & Internet
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
Power issue Toshiba Satellite m35x-s161
Unfortunately there are many sellers of DC jacks for your model and several others. Some of these people sell sub-standard DC jack replacements which are not designed for your laptop, but will fit in the same hole. If the mount points for your DC jack didn't fit the same pattern as your original one then it simply is not the right jack for your laptop. You can suffer issues such as improper grounding, voltage applied to ground and vice versa with some severe consequences. This can damage not only your charging circuit, but may well cause your battery to overheat and rupture. Remember, that not all DC jacks are designed the same way, In fact most manufacturers design their jacks as different from the competition as possible, whether this is their intent or not is irrelevant. Your Dc Jack, however suffers from the dreaded floating pin problem. The main bullet type pin you see at the middle of your jack tends to separate and spin freely, and can be repaired by simply soldering the pin mount on the back. Try repairing the pin on your original jack and reinstalling until a new jack can be found and I'd be willing to bet your problem goes away.
Mar 14, 2010 | Computers & Internet
REPLACING A BROKEN POWER JACK ON A SONY VAIO
Hi:
The power jacks can be bought on line for less than $10, but the fun part is the repair. The laptop must be dis assembled to get at the power jack, and when you do get to it, it takes a deft hand and soldering skills to swap one out successfully.
I have done a few and am personally only about 50% successful. There are electronics shops that swap out the power jacks for about $150, and guarrantee their work.
Nov 22, 2009 | Computers & Internet
How to open the power jack for GQ-zx 5361 laptop . and replace it with new one...
1.ESD wrist ********, connected to a good ground, work on a table.
2.Remove the AC adapter if plugged in, and the battery.
3.Completely disassemble the laptop, down to just the bare motherboard in your hand.
4.Use your soldering station, and I advise using a soldering wick instead of a desoldering tool, on the DC Power Jack leads. Works much better.
Remove the old DC Power Jack, being careful to not burn the motherboard, lifting the circuit traces, and rendering the motherboard useless.
5.Clean the DC Power Jack mounting area with Isopropyl Alcohol, and Q-tips to remove the residue. [WARNING! Isopropyl Alcohol is =>Extremely Flammable. I use the 91% Alcohol version]
Make sure the circuit trace mounting hole has a good tinned surface.
6.Install the new DC Power Jack in the circuit trace mounting holes. CAREFULLY apply solder to the DC Power Jack leads, and be sure to make good solder joints.
7.Reassemble the laptop
Sorry, I don't have access at present to Fry's GQ line of laptops for a Maintenance and Service Manual, to give you a link.
Aug 20, 2009 | Computers & Internet
Thermal cooling assembly replacement or Thermal paste
Frankly there is seldom a reason to replace either. The thermal grease is not damaged by removing the assembly and, as long as there is still plenty, you can just reassemble it. There is absolutely no reason to replace the assembly.
Mar 21, 2009 | Dell Inspiron XPS Gen 2 Notebook
Sony VAIO FRV25 Notebook Logo
128 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
