Question about Hitachi 46UX50B 46" Rear Projection Television
Hitachi model cu4601b/k
Television led lamp will light when power button on remote is pressed but will go off before turning t v on ,you can press remote again and hear a click in unit but will not power up. any ideas would be helpfull, thanks
  • FELISAP Nov 03, 2007
    I HAVE A HITACHI CU4601B AND IT WENT OUT. IT WILL POWER UP BUT LINES ARE ON THE TV THEN IT JUST TURNS OFF.WHAT COULD THE PROBLEM BE
  • hatroc Jun 09, 2008
    have 46ux17k hitachi ulratvision youturn on and hear a click same as turn off but there no picture or volume any suggestion on what it could be and how expensive to fix or worth fixing
I have a Hitachi 46UX50B that just faded out one day when the screen picture faded with green and red coloring and now does not power up. I thought it would be the projection lamp, but just brought it in for an estimate and was told the high voltage transformer needed replacement. I had the same symptoms you describe when trying to turn it on....maybe this will help.
Posted on Jun 20, 2007
I had this problem in a 46UX50B (I think that's the model), and it turned out to be some capacitors in the power circuit(?). After the service guy replaced those, it hasn't failed to come on since.
Posted on Apr 17, 2007
My Hitachi 57F710 TV turns off as soon as it turns on?
The model indicated is a DLP which uses a lamp---lamp will not usually cause set right on and then instantly off----takes it 15 seconds or so if lamp has failed.
Also set has led on front that may blink.
If instant it is turned on it goes off----you have a short likely in power supply or elsewhere.
If you have more information or a question press the "make a comment button" on this page.
Mar 26, 2012 | Hitachi 57F710 TV
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I need the codes for ge universal remote controller model #J021
    You can programme your remote by below method
    Manual code entry
    1.Turn on your television or other electronic component that you want to program the remote control for.
    2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
    3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
    4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
    5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
    Auto configuration
    3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
    4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
    5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
    You can get your codes from below website
    http://www.jascoproducts.com/support/universal-remote-codes.asp
    Thank You
    Sep 19, 2010 | GE RM24930 Remote Control
    Need codes for programing a hitachi tv
    The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
    May 22, 2010 | One For All URC-3021 Remote Control
    Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
    Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
    Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
    Replacing lamp
    try this to see if it works!
    If you replace the DLP lamp out of your Zenith or LG, you will need to reset the
    counter…Otherwise you may get an annoying reminder every few days if you’re
    surpassed the predetermined hour mark.
    Ensure the TV is powered on.
    Press and hold the MENU button on the TV
    Press and hold the MENU button on your REMOTE
    (hold both these until the service menu pops up 5-10 secs max.)
    Let go of the REMOTE button first, then release the button on the TV
    Press and hold the ENTER (or OK) button on the TV
    Press and hold the MUTE button on the REMOTE
    (hold both until the LAMP LIFE HOURS appears on the screen)
    We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference
    To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter
    For certain models, you might have to tweak these steps slightly… offer your inputs!
    Apr 26, 2009 | Zenith E44W46LCD 44" Rear Projection...
    How do you reset the warning to replace lamp.i replace the lamp on my pt-50dl54 but the replace lamp still comes on
    Turn your television on
    Press volume down on the TV
    Press the mute button on the remote
    Green LED light on power button will flash
    -timer now reset (no more warning light)
    Nov 15, 2008 | Televison & Video
    How do I reset the replace lamp message
    Do you have a picture? If so the only way to reset this unit is to get a Zenith programmer remote. With this remote you can get into the service menu and reset the lamp timer and that will reset the unit.
    Dec 31, 2006 | Zenith D52WLCD 52" Rear Projection...
    Televison & Video Logo
    161 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Steve Allison
    Steve Allison
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
