The head has adjustable weighting, and a screwhead broke off while i was changing the weights.
SOURCE: 1.6 gtd driveshaft weight.
cut it off and dont worry about it.put on a new boot clean greese.you will not notice anything with that off the axel.i have done it many times
SOURCE: 2002 Volkswagen Golf What kinda oil dose my 2002 volkswagen golf
your local motor shop stocks many oils that will suit your car cheap oil more expensive but better oil you obviously have to go buy the oil so ask at the shop and get something desent
SOURCE: 98 Chevy Venture. Sounds like golf balls in the engine.
it could be either,main bearings or rod bearings,you seem to have a handle on it,now all we can do is take bets when the big knock happens!
Testimonial: "Thanks"
SOURCE: My electric hydraulic pump for my 97 f350 does not
Check the details on the pump to see how much it should lift. If it is nort performing to specs, youm may need to rebuild the pump, replacing the seals,
