Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
Clean cycle blue light **** on wash cycle won't start
How do I reset the panel?
  • 1,031 Answers
Try pressing stop/clear press and hold timer for 5 seconds this should reset the panel.hope this helps
Posted on Dec 23, 2008
My Hobart A200 lift arm seems frozen. Sat in garage covered.....won’t lift.
There are a few retaining screws in the guide's that you can undo to clean the runners. They get gummed up with flour over time. This should help
May 17, 2018 | Hobart Food Mixers
My food disposer has no sound I need help. Could you help me?
If you open the cabinet door under the sink, you should be able to see the disposer motor. On the bottom or side, there should be a small bump that is the reset button. Push the button in and it should work again.
If it still does not work, make sure that the power cord is plugged into the outlet.
Still not working? Check the fusebox for a blown fuse or tripped circuit breaker.
One last idea: if the outlet that the disposal is plugged into is a GFCI protected plug, there will be a TEST and RESET button in the center of the outlet. Unplug the disposal cord, press the RESET button on the outlet, then plug the disposal cord back in.
Aug 31, 2015 | Food Mixers
Why won,t it start
Make sure you have power at that outlet. If so, unplug and look for damaged cord. Then open and look for blown fuse.
Jul 22, 2014 | Farberware 12-Cup Food Processor w/ 4-Cup...
Can a reset button be replacedon a R2U Ultra robocooupe? Model #005500
I can not see the machine if reset button broken? it can be replaced if it is a fuse-able button ,
Mar 20, 2014 | Robot Coupe Food Mixers
Model khm9qwh5 won't start
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Nov 05, 2012 | KitchenAid Food Mixers
Delonghi DSM7 Stand Mixer won't start after overheating. Is there a reset button?
take it in to an appliance repair shop for a proper diagnosis and quote but it is probably not worth repairing ( armature and brushes )
Apr 09, 2017 | DeLonghi DSM7 Stand Mixer
Mixer won't turn on
Just recheck that you really have put the brushes back in the right way, use a torch and look in the hole. The brushes can each go in 4 ways, only one of which will work. Look for the blocker and line it up with the cut off corner on the brush. It's normally at the back, one side at the top the other at the bottom. After that you need to be looking at everything you have done for a booboo. I doubt it will be water ingress. Make sure the switch contacts come together when the lever moves to position 1.
Mar 18, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer went into over load useing a stactic converter wont come back on no noisewhen turn on
This sounds the thermal reset is tripped have you looked for a red reset button on the mixer? that is usually what fixes that
Feb 28, 2011 | Hobart HL600 Legacy Stand Mixer
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
70 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
