Question about KitchenAid KGRA806PSS Gas Kitchen Range
KGRA806PSS00 stays in preheating
I have a 4-year old KitchenAid KGRA806PSS00. When I set the temperature, it stays in Lo and Preheating forever. The only way to get it out of this is to turn it off and try again. Usually, on the 2nd attempt it starts heating after 2-3 minutes. It typically does this about 50% of the time. The over has done this for a few years.
I do not believe it is the Thermostat, since I just replaced it due to the "Oven Cleaning Problem" blowing it. That has happened 4 times to me with this oven.
Master_Tech
  • 770 Answers
SOURCE: ge spectra xl44 Preheating Issues
bad oven sensor
Posted on Jan 26, 2008
aborcass
  • 2651 Answers
SOURCE: KGRA806PSS00 oven dead after self cleaning
heres the part number for the saftey thermostat 8300802
Posted on Apr 08, 2008
ngfam1
  • 639 Answers
SOURCE: problem with oven preheating
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
scottowa
  • 87 Answers
SOURCE: Oven not heating
On the bottom is a link of what your oven is. I'm pretty sure it's the ingnightor #16. You should see a glow red hot when you turn on the oven or broil. Very common problem and pretty reasonable price to repair. Unless that glows and get's red hot, it will not turn on the gas. I think that should do it. Let me know if you need anything else. Scott
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=SF325PEEQ0&productCategoryId=0124002&brandId=1198&modelName=Free-Standing,-Gas
Posted on Apr 19, 2009
  • 180 Answers
SOURCE: The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Posted on Jan 30, 2011
What does it mean when your Samsung flat top oven and broiler will not work and the code reads E-08
E08 Error Message on a Samsung Electric Built-in Oven:
The E08 preheating error code appears if the set oven temperature is not reached within 50 minutes. If this code appears, the reason might be due to overheated thermostats, a defective heater or a defective relay; in which case a repair will need to be arranged.
However, if food has been put into the oven during the preheating time that may cause the error code, since the presence of food cools the oven and so it doesn't reach the right temperature. The error message can be removed by turning the oven off and turning it on again.
To prevent this error code from happening again, the oven should not be used during the preheating period. The preheating period ends just after the sound signal and the icon in the display have turned off. When the oven gives the signal, it's close to the set temperature and your food can be put in.
Apr 14, 2015 | Samsung Kitchen Ranges
Ran the self cleaning cycle and now the preheat light will not turn off when it gets to the temperature I set it to. It just keeps preheating. Example: I set the oven for 375. It seemed like it had been...
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Feb 20, 2014 | Ovens
Gas range won't hold temp after preheating
Did the main valve open and then shut off, or does it never reopen? The main valve should be open while the sparks are jumping...
Jul 23, 2017 | KitchenAid Kitchen Ranges
How do I shut off the 4 hour delay button?
see this possibles causes:
Water pre-heating
the water must be preheating, if do not doing increase the temperature water, this problem will take 1hour, causing the problem too long
The heating element can be faulty or thermostat, test it see how.The cicle can continue and goes on and NOT STOP.
Cycle not completing
timer can be defective: clean contacts, tight for loose wires, break, or burn and repair. God bless you
May 25, 2012 | KitchenAid KUDS30SXSS Builtin Dishwasher
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Problem with oven preheating
Hi, I'm Neil
Thank You
Neil
Jul 14, 2008 | Maytag MGR5750 Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
128 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
