PC does not recognize emerson music stick device
When the music stick is plugged into the usb port of my computer (VISTA) recognizes the device but I get a message saying FILE SYSTEM ERR on the music stick as well as VISTA sends a pop up window saying device not loaded. Needless to say I cant transfer music to the stick. Explorer does not recognize any file stucture of the device. What is wrong?
  • tainowoman Jan 03, 2009
    I have xp and the same thing happens. It is not downloadable.
  • grs4590933 Jan 10, 2009
    i have the same problem with xp can any one help
bsrjth
  • 270 Answers
SOURCE: My computer does not recognize my 1GB memory stick whn I connect to the USB port. What can gone wrong? Thanks.
some flah drives need drivers . i think u r not using xp . the drivers can be downlaoded from the companys websit . can u ane the comapny
Posted on Dec 07, 2007
Tel1
  • 14 Answers
SOURCE: Motherboard not recognizing RAM
If you're running XP SP2, that may be by design because of something Microsoft did in SP2.
Look at the following article for an explanation.
http://support.microsoft.com/kb/888137/
Posted on Dec 25, 2007
  • 5 Answers
SOURCE: memory stick pro duo pc connection
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Posted on Feb 11, 2008
  • 919 Answers
SOURCE: File transfer VN-480PC doesn't work on notebook (Vista)
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Feb 19, 2009
SOURCE: EMERSON MP3 MUSIC PLAYER, EMP312-1, "FILE SYSTEM" ERROR
ok here we go i dunno how i figured this out lol but it took a while. okay so ur gonna go to control panel, device manager, and uninstall the driver for mp3 player. then disconnect mp3 player and reconnect it to reinstall mp3 player. it will recognize it as emerson mp3. right click on it (im running xp) go to properties, click on the tools tab and click on check now on the error checking and select both options of automatic fix file system errors and scan for and attempt recovery of bad sectors. then hit start and it will start the process of fixing the file error. it takes a couple minutes and when its done disconnect the mp3 player n turn it on and voila!!! it works again. if u need more help u can e-mail me at davidh9732@hotmail.com. hope this helps yall so u dont throw them away
Posted on Apr 10, 2009
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
No pc recognizes the V-touch 8gb mp3 player by Visual Land
Windows xp, Vista, and Windows7 should already have a driver included for the v-touch. It's possible that if your computer has a compact flash card reader, that it maybe preventing the v-touch driver from being correctly installed. Try using the "Safely remove Hardware" to temporarily remove your cf card reader. Then try plugging in your v-touch. It should now correctly install the driver and the v-touch will show up as a new drive. In Windows Device Manager under "Disk Drives" you should see 2 new devices - "Company PNP Platform OPN USB Device" and "Company PNP Platform SDC USB Device
Dec 21, 2009 | Visual Land V-Touch Digital Media Player
My d610 does not recognize my cd drive
Is the USB-compatible drive recognized when connected to some other computer? If OK, then the drive is OK.
Is _ANY_ USB device (memory-stick, camera, mouse, keyboard, printer) recognized when connected to any of the USB ports on your computer?
If not, then the USB device-drivers for Windows have not been loaded.
Drastic: backup all your data files, bookmarks, and music, to an external hard-drive, and reinstall Windows from the Dell-provided "System Restore" set of CD-ROMs.
Nov 14, 2009 | Dell Latitude D610 Notebook
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
I need help opening a file saved on my memory stick with my pc
IF the win98 box wont recognize the usb stick you will need to install the drivers in order for the OS to recognize the device, after this you should be able to see the device and files on it
Jan 22, 2009 | Computers & Internet
Sansa c240
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sync music to psp
  • Hook USB cable between the PSP and PC
  • On the PSP under Settings, select USB connection
  • Your Vista PC should recognize that the PSP is connected. The PSP should be displaying "USB Mode".
  • On the PC add music to the removable drive that represents your PSP memory stick. Put the music in the Music Folder.
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
USB Drive
Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
66 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
