Question about Eclipse CD5000 CD Player
CD 5000 i'm having problems with my majic gate memory card. when i insert it into the slot with audio files on it the screen says "MS INFO 2" and nothing works.. i tried puting the files on the majic gate in Mp3 format and then in wav format and neither seem to work.. any answers would be greatly appriciated.. Thanx CJ
Show your memory card location
Remove the back cover by holding the phone firmly then slide in the back cover of the handset. You will now see your MicroSD and SIM card slots. Take your SIM card and slide it into the slot provided with the chip facing down. You will also see a small diagram showing you which way to insert the SIM card. Now slide open your MicroSD memory card slot gate, pop your MicroSD memory card into the slot, then close the MicroSD memory card slot gate by sliding it forward then backwards.
Oct 29, 2011 | LG GD510 Cell Phone
How do i find out what are all the plugins are for om my acer 1100 desktop
1) Outside the computer case;
Front:
A) 4 USB ports (Using USB 2.0 technology)
B) 1 Headphone Jack
C) 1 Microphone Jack
D) 1 Memory Card Reader;
"Multi-in-one Card Reader supporting CompactFlash® (Type I and II), IBM Microdrive, xD-Picture Card™ (xD), Secure Digital (SD), SmartMedia™, MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO™ (MS PRO) (selected models)"
Rear:
A) 1 PS/2 Mouse port
B) 1 PS/2 Keyboard port
http://en.wikipedia.org/wiki/File:Ps-2-ports.jpg
C) 1 Parallel port
http://en.wikipedia.org/wiki/Parallel_port
D) 4 USB ports (Using USB 2.0 technology)
E) 1 VGA port. (For an external VGA monitor )
http://en.wikipedia.org/wiki/VGA_connector
F) 1 IEEE 1394a port (Firewire port)
http://en.wikipedia.org/wiki/Firewire_port
G) 6 Audio ports
2) Inside the computer on the motherboard,
A) 1 PCI Express x1 expansion slot
B) 1 PCI Express x16 expansion slot used for a graphics card. (Uses the PCI Express 2.0 technology)
{250 Watt ATX power supply}
C) 2 PCI slots
Acer Support > Acer Aspire M1100 series of desktop computers > User Guide,
http://www.acersupport.com/us/en/product_support.aspx?tab=1
Go to the bold heading > User Manual
Click on the blue >
ASMx100_EXE210_VTMx10_UG_EN.zip
After you click on the above file name a small window will come up.
If there isn't a Green dot in the circle to the left of Save File, click on the circle.
Make sure there is a green dot in it.
Now go below, and click on OK.
Another small window will come up, that has a download progress bar in it.
Write down what is in the top heading of the window.
This is where the Zip file will download to.
It may have Desktop, or My Documents, or Downloads in the info at the top of the window.
Desktop: The file will be on your desktop screen.
My Documents: Click on Start > My Documents
Downloads: Click on Start > My Documents > Then double-click on Downloads
When you see the file name double-click on it
( ASMx100_EXE210_VTMx10_UG_EN.zip )
Another window will open up.
Click on > Unzip
On the top left click on Extract All Files.
Click on Next, Next, and Finish.
Now double-click on the file name next to the red PDF icon.
There's your user manual.
If I have left something out, or the above is not what you had in mind, or you have questions,
post in a Comment.
Would like to hear back from you.
Regards,
joecoolvette
Dec 10, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
How do i format my sd card via bluetooth
I'm sorry but u have to manually format ur memory card using the phone or a computer...
back up ur files first...
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located on the left side
  2. From the standby screen, press the right soft key for Menu
  3. Select My Stuff (7)
  4. Highlight the On Card tab, using the left or right navigation keys
  5. Highlight either Audio, Graphics or Videos, using the navigation keys
  6. Press the left soft key for Options
  7. Select More (4)
  8. Select Memory Card Settings (2)
  9. Select Format (2)
  10. Press the left soft key for Yes to confirm formatting the microSD Memory Card
  11. If prompted to rename, press the left soft key for Save
Dec 14, 2009 | Samsung Propel A767 Cell Phone
Wrror message C13:01. Keep saying insert memory
First you have to find out if the problem is caused by the camera or by the MS. Replace the MS. In case of wrong MS you may restore photos in some card reader using some freeware restoring SW. In case of wrong camera check pins for MS in the slot.
Oct 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Trying to locate where to put a memory card
Hello, was wondering if you meant memory card or memory chip. If it is a chip, it goes next to the other memory chip in the slot. Must be right memory or the motherboard may fry out.
If it is a memory card, you must have SD-MS slot. If you do not have the slot, you can by one and hook it up to the pci slot.
May 22, 2009 | Compaq Presario 5000 PC Desktop
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Clie T615 not reading memory stick
Either the stick is defective or the wrong format.
May 04, 2017 | Sony CLIE PEG-NX60 Handheld
My memory card is inserted, but its telling me its not!
first is try checking its memory terminals maybe their something blocking it or you inserted it in a wrong position.
or try restoring your phone to its factory settings...
 if still nothing happens maybe you have a defective memory card. or to be sure try using other memory card, if still cannot read it theirs a prob in your memory slot internally....
hope you solve it...
Jun 23, 2007 | Sony Ericsson W300 Cellular Phone
Car Audio & Video Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
