Scytek 2000RS Remote Control Logo
Posted on Sep 03, 2012
Idle speed relearn 08 pontiac torrent - Scytek 2000RS Remote Control
1helpful
Sim number for Pontiac torrent remote?
2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob ...
www.amazon.com/...Pontiac-Torrent.../B009E9LX5O
Amazon.com, Inc.
Rating: 5 - ‎4 reviews
Amazon.com: 2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob With Free ... Manufacturer Part Number, Part #: 15913420, 20869056, 20952475 ...Missing: sim
2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button ...
www.amazon.com/Pontiac-Torrent...Remote/.../B0068...
Amazon.com, Inc.
Amazon.com: 2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button Models with ... GM Part Numbers: 20868672, 20952474, 15913421 w/ Remote Starter ...Missing: sim
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ...
? 3:28
https://www.youtube.com/watch?v=OASrgxUXXdI
Nov 7, 2012 - Uploaded by Lessco Electronics
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ... Press the set/reset button until REMOTE KEY ...Missing: sim
How long the job takes to change an heater core for an 08 Pontiac torrent
2006 Pontiac Torrent Need to Replace Heater Core, Heater ...
https://www.2carpros.com/.../pontiac-torrent-2006-pontiac-torrent-need-t...
Nov 5, 2010 - Heater problem 2006 Pontiac Torrent 6 cyl All Wheel Drive ... BIG jobinstrument panel must be removed AC discharged, SIR deactivated ect. ... Why did youtake in? ... How to replace a heater core in a 1998 ford f150 4x4 5 4.
Heater Core Replacement Cost for Pontiac Torrent ...
repairpal.com > Estimator > Pontiac > Torrent
How much does it cost to replace a heater core on a Pontiac Torrent? Make sure it's a fair ... heater core. Cheap heater cores tend to leak and not last very long.
Pontiac Torrent Repair: Problems, Cost and Maintenance
repairpal.com > Cars > Pontiac
A guide to problems, costs, maintenance and repair for your Pontiac Torrent. Problems. Verified by ... after changing bcm radio is locked and wont play. 2006 Pontiac ... 2008 Pontiac Torrent. 0 answers ... Heater Core Replacement. Pontiac ...
2006 Pontiac Torrent Heater core - Questions - Fixya
My 08 uplander has a bad throttle body how do i
Unplug the battery and turn your headlight switch on for ten minutes.Then hook up the battery and turn the headlights off
Procedures for idle speed relearn for 2007 pontiac torrant
Is the free instructions explaining the idle speed relearn for a 2007 pontiac torrent?
What controls the radiator cooling fans in the ac mode on a pontiac torrent 2006
Well the computer activates the relay for the fans when needed.
You should be able to jumper the relay to check the fan operation.
The fans come on when the ac pressure reaches 200psi or so, not as soon as you turn the ac on.
2003 tahoe how to do a idle speed relearn 5.3
All you do is disconnect the battery NEGATIVE cable for 5 minutes and then reconnect, over the next few miles your system will relearn idle. This will not correct any idle problems such as stalling or erratic idle, this would be caused by other problems many of which WILL NOT SET FAULT CODES.
Fast idle
Unhook your battery cable for ten minutes.Reconnect it and let the car idle for five minutes,then drive it normally and it might relearn to idle again at correct speed.This is just something I would try,as it can prove to be a very simple fix. don-ohio (:^)
Can i rotate my tires myself with tpm on 2008 torrent
yes you can. just back sure you torque the wheels correctly. and the light might come on but just drive it a bit and it should relearn itself. happy motoring!
2helpful
1995 pontiac firebird formula v8 idle
The idle speed is not adjustable, it is computer (PCM) controlled, you can turn the screw for the hard stop, but the computer will just over ride that adjustment for the most part, what I think you may need to do is clean the throttle valve and the idle speed control air bypass valve, use carb spray, spray it in the intake with the engine running use the at least 1/2 the can, the engine will try to stall, keep it running, after you are done disconnect the battery for 10 minutes, reconnect and drive a few days so the computer (PCM) can relearn your driving habits and set the idle correctly based on your driving.
Top Scytek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
