Question about Baby Lock Ellure
Balance wheel locked on crafter's choice
I have an error E6 that states the motor is locked up because the thread is tangled. I have removed the spool and re-threaded the machine and cleaned the shuttle and the message still shows. The balance wheel won't move. How do I fix this?
    Scholar:
  • 65 Answers
Try this site and see if the download gives you a troubleshooting code.
http://www.babylock.com/downloads/instructions/?Update_ID=95
Babylock.com has really good cust. service, but your dealer should know what steps to take to clear this code.
If the sell an addtional information book on your machine, and stitching BUY it, it was so worth my $70 for my Evolve book (200+pages of HOW to's for that 8 thread monster!)
I hope this helped
Posted on Jan 25, 2009
I keep getting the e6 error message for tangled thread but when i go to fix the tangle there isnt one and both bobin and spool spin freely any help would be great im at a total loss
The "thread out" sensor can be triggered if the thread is not between the tension disks. That is usually caused because you threaded with the presser foot DOWN. You MUST raise the presser foot when you thread your machine; that is the only time that the tension disks are spread to accept thread.
May 10, 2015 | Brother SQ9000FS 80/120 Stitch & Alpha...
After 3-4 stitches, machine shuts down. On display panel E6 show up.
Error codes are on page 62 of this manual.
It says " The motor locked up because the thread is tangled.
Remove the tangled thread before continuing operetion."
I would guess that this could happen for anything that would cause too much load on the motor.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CE_5000PRW_EN_1444.PDF
Sep 24, 2014 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
I have a Brother XR6600 - today I got an E6 error indicting tangled thread. Ihad a check and cleaned it but no thread. When I try to sew the machine jam's ..... Help!
try these things
new needle
rethread machine--presser foot & needle to highest position
keep a check on the thread take up lever, when the top thread come
off the thread take up lever it can also make the machine jam
Jun 05, 2012 | Brother Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
My sewing machine will sew for about 2" and then
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
Above is a link to the PDF file for you sewing machine.
The error message E6 is The motor locked up because the thread tangled.
Solution - Remove the tangled thread before continuing operation.
Jan 17, 2011 | Brother CS6000i Computerized Sewing...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Machine is telling me E6 error but there is no thread tangled
If your thread is not tangled .The E6 will come up also if the top thread is not threaded properly. Is your thread breaking at all ?
Dec 13, 2008 | Brother CS-6000
Sewing Machines Logo
615 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
