Question about Rinnai RER-55AS 55-Cup Rice Cooker
I have the new part I am just trying to locate proper install/ take apart instructions. Thanks in advance.
3 Suggested Answers
SOURCE: rinnai 606tra error code 31
i didnt fix it i did pay my 10.00 and what i got in return was i think , was an expert telling me to read the manual
Posted on Oct 05, 2008
  • 56 Answers
SOURCE: rinnai r94lsi comes on 5 sec. then off
if it's a gas unit you mite have to bleed the gas line in and out.
Posted on Jan 05, 2009
Can Stretch tell me where the oil pick is located on a twincam88?
There is no pickup. Did you have the cam plate and therefore oil pump apart? If so you may have failed to properly install the pump parts and align them properly OR you may have missed installing an o-ring or etc.
Apr 05, 2014 | Harley Davidson FLHR Road king Motorcycles
Windows7 registery
Hi,Dear Friends..
Your win7 registery not repair i think some problem occur.
Flow instruction:-
1> Change you current windows7 cd. because i think some error obtain.
2> Another you DVD ROM lance week and not read CD properly.
3> Your Hard Drive create bad sector. When you install windows.
A> Used new windows7 CD.
B> Change DVD ROM Driver.
C> Change HDD Device Driver.
D> Change Install windows location.
Feb 15, 2013 | Toshiba Satellite Computers & Internet
How to install
Unfortunately, the installation of one of these units is not quite as simple as 1, 2, 3.
So, I am providing a couple links on the installation process. You can download and print each one.
The first is the Flue Installation Guide.
The second is the Operation Guide, which also deals with proper installation.
The third is the exploded parts view & parts diagram, Which you may need in the future.
I hope all of this information will help you properly install the unit.
Jun 02, 2011 | Rinnai EnergySaver 556 Air Conditioner
Windows xp says no drivers for this device
hi try this ... if you are installing a new device it is recommended that you install the software first then restart your pc and plug/connect your device !then go to Start,control panel , add hardware follow the on screen instructions add new hardware /yes i have connected the new hardware( then if you cant find the new hardware) just choose/ add new hardware device /search and install automatically !it should find the files for it to install properly
please rate this if found useful , many thanks it only takes 1 second
Dec 21, 2010 | Computers & Internet
Rinnai R50LS- water doesn't heat, even though there is good flow.
If it's a new install: the water is going backwards through the heater and you need to check that your cold water IN is actually hooked up to the cold water IN spot on the heater. they don't register flow if the flow goes backwards through the heater.
If it's not a new install: something is stuck in your flow sensor, drain the unit and take it out to check.
Apr 16, 2010 | Rinnai Water Heaters
Its not starting as good as it used to
Try running Chevron Techron concentrated fuel injector cleaner in a 1/4 tank of gas.
Also, may be the issue in this TSB.
ISSUE: A hard start or no start condition may occur when the engine is cold. The engine may not start without cycling the key to the OFF position and back to START. Ignition switch bounce (loss of electrical continuity between contacts) may cause the EDIS module to recycle several times or to lock-up and not allow a start at all.
ACTION: Install a new ignition switch containing synthetic lubricant which reduces the amount of bounce. Also, install a new wiring connector containing a new material that is compatible with the new synthetic lubricant. Refer to the following procedure for service details.
  1. Disconnect the battery power.
  2. Remove the trim panel. Refer to the 1990-91 Ranger/Explorer Shop Manual, Section 11-04B, for removal procedure.
  3. Turn the lock cylinder to the RUN position.
  4. Remove the two (2) nuts on the ignition switch.
  5. Separate the connector from ignition switch by gently prying on the ears of the connector and pulling apart firmly.
  6. Disengage the terminals from the existing connector. Discard the connector.
  7. Insert terminal into proper locations in new connector (F2TZ-14489-A), Figure 1. INSTALLATION
    1. Remove the spring clip from the new switch (F2TZ-11572-A). This clip keeps the switch in the correct position during shipment.
    2. Press the new connector (F2TZ-14489-A) onto the terminals of the ignition switch. Be sure the tabs lock securely.
    3. Locate the switch on the weld studs on the steering column. NOTE: THE END OF THE ACTUATOR ROD MUST FIT IN THE HOLE ON THE SLIDER.
    4. Install the nuts on the weld stud. Tighten to 4.45-7.24N-m (39-64 lb-in).
    5. Connect the battery terminal.
    6. Check the switch operation. If necessary, adjust it. Refer to the 1990-91 Aerostar, Explorer, Ranger Truck Shop Manual, Section 11-04B, for adjustment procedure.
    7. Install the trim panel.
    PART NUMBER PART NAME F2TZ-11572-A Ignition Switch F2TZ-14489-A Wiring Connector
Nov 12, 2009 | 1991 Ford Explorer
Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Jan 24, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Need instructions to install replacement fan/motor for Home Theater
now, why am not may take some pretty handy with tools? also, turn off the box, and let
let it discharge for a while..
Oct 24, 2008 | Audio Players & Recorders
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai RER-55AS 55-Cup Rice Cooker Logo
47 people viewed this question
Top Rinnai Kitchen Appliances - Others Experts
Paul Carew
ray gallant
Are you a Rinnai Kitchen Appliances - Other Expert? Answer questions, earn points and help others
