Question about AOC LM 720 17" Flat Panel LCD Monitor
AOC LM 720 Flat Panel LCD Monitor
My AOC LM 720 Flat Panel LCD Monitor has a problem... It only displays a bright white screen when its switched on. The bright white appears whether it is connected to the computer or not. The brightness controls have no effect and other monitors work fine when connected to the computer. It's got me a bit baffled, most of the LCD monitor fault-stories I've read are all back-light related but the back light in this one seems to be fine. Any ideas?
  • 22 Answers
Try to check the capacitors
Posted on Jan 08, 2009
  • 105 Answers
The all white screen indicated the 5 volt supply to the LCD panel is not there. The panel used the 5 volt supply to "black" out the picture. Usually the mini fuse on the panel circuit board has opened. 99% of the time there is a short in the LCD circuits that blows the fuse. Replacing the fuse will usually result in the fuse blowing again immediately.
Usually requires a panel replacement which is costly.
Monitor Mike
Posted on Apr 25, 2010
4 Suggested Answers
  • 4 Answers
SOURCE: AOC LM729 LCD - Go to; bright white lines, blank, computer view and lines, blank. Yeah, please help!
This is an old post but maybe this will help someone else......
I have sold a lot of these LM729's a few years back and now, out of warranty, they are starting to show these same symptoms. I was stumped at first but finally did some real testing on them and found that in every case it it the 1000uF capacitors that are faulty. Look at the board and you will see 2 capicitors, the barrel shaped components, that have 1000uF printed down the sides of them. Both of these should be replaced even if only one is bad because chances are the other will go soon as well. You can usually pick these up for under 2 bucks each at your local Radio Shack. Get ones rated for 35 volts (35V), the ones on the board are 16vols but I usually try to go a bit more robust when I replace capacitors. The rating is just how high the voltage can go so it's okay. They are usually more durable since they are to handle higher voltages. Just take the LM729 apart, remove the power board, desolder the capacitors, clean up the holes, (Be gentle in desoldering them, you don''t want to pull the things, you will pull off and possibly tear the copper foil pad that you need to solder the new cap to) Install the new capicitors minding the polarity, as in there is a MINUS sign on the capicitor and this must go in the hold with the matching MINUS sign. Solder the leads, clip the excess off. Reassemble and you'll probably find that LM729 working just fine! These are very good monitors and very rugged. AOC isn;t at fault for this failure. The Chinese have been making scads of bad capicitors for a few years now. Anymore, if there is an electronic failure it can be traced back to bad capicitors.
Posted on May 02, 2009
  • 26 Answers
SOURCE: AOC LCD monitor black out..Please help?
Sounds like bad video card drivers..Try updating the drivers from the manufacturer's website. Give us the details of your video card/ PC.
Or it could be monitor related. Open the monitor and check the power supply. Make sure there are no bad capacitors inside. If you find any replace them with new ones with same number or bigger capacity,
Posted on Apr 02, 2010
benwabnick
  • 2404 Answers
SOURCE: (external monitor AOC LM765 flickers white
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
Posted on May 15, 2011
Contrast box keeps appearing
Seems the menu button of the monitor is stuck. Turn off the monitor and the with the main power supply. Spray an air duster or w40. then try to push one after the other and check it the button is working much better now.
Feb 22, 2011 | AOC LM 720 17" Flat Panel LCD Monitor
I need a power cable for an LM720a monitor
There is a new one at Amazon.com.
heres the link.
http://www.amazon.com/HQRP-Adapter-Monitor-Replacement-Coaster/dp/B0025UAFYE
Aug 30, 2010 | AOC LM 720 17" Flat Panel LCD Monitor
Power supply seems to be bad
No. All you need is to plug it in the monitor first before plug in it into the mains. The power supply of the monitor has its own capacitor that needs to be charge and the way to charge it is to plug it in to the monitor and turn it on working for at least 20 minutes. You will see the difference.
Oct 05, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
Displays 'Input Not Supported' at start up om black screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Sep 20, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
Screen blinks to black, but the LED indicator is still GREEN
Get both inverter board and backlight fluorescent bulbs from eBay.
Jul 04, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
AOC LM700 17" LCD Screen switches to black and then comes back to normal. Power light never goes green but monitor works. LED is orange when off and in sleep mode, wakes correctly on getting input. Just...
According to LCDParts, an inverter for an AOC LM700 would cost $69.99. Specs (with picture) are available here.
Perhaps you can do a Google for lesser priced versions.
Good luck and kind regards.
Feb 08, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
Lm720a 17" monitor switches it's self
try to resolder all lost contact on flyback transformer..............................
Oct 11, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
Monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
Aug 18, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
AOC LM 720 17" Flat Panel LCD Monitor Logo
1,330 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
