Question about Kenmore 63942 Dryer
Putting Belt back on Kenmore Dryer 63942
Need to know how to put the belt back on the dryer?
  •  Sherman
    Sherman May 11, 2010
    do you have the dryer apart
  • Anonymous Mar 30, 2014
    dryer belt came off and can't get it back on
  • Kenmore Master
  • 8,220 Answers
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out, clean out the dryer witha vacuum and use this belt routing pic for reference:
CLICK HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 28, 2008
Putting on a new dryer belt on a 417.83142200 serial number is XD24613789
Hi and welcome to FixYa, I am Kelly.
Download this manual:
http://applianceassistant.com/pdf/27gasElectricDryers.pdf
See page 19 for removal of the top (printed on the page 14'
See page 20 figure 19 for removal of the toe panel.
See page 24 for removal of the door after opening the toe panel (bottom)
I note this is a 417.xxxxGGGG dryer (417) so if the manual above is incorrect for your dryer let me know.
Correct Belt routing diagram is here: (Diagram B)
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramB
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Kenmore 63942 Dryer
..How do i Get to the belt Of a Kenmore70 dryer My
there should be an access panel in back. look at the way the belt is on and remeber how you take it off. that will help you understand the process for putting a new one on.
Kdog
Dec 29, 2010 | Kenmore 63942 Dryer
How do you rehook the belt up for the drum
tricky but belt around drum then pully tensioner at bottom of dryer the belt feeds through pully then onto motor gotta move pully while putting belt on motor take s some practice kinda hard to expain
Aug 19, 2010 | Kenmore 63942 Dryer
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
The belt on my kenmore series 70 dryer is broken how do I repair it?
remove the 2 lint screen screws,pull the top toward you and up,disconnect the door switch,remove the 2 front top screws on the front panel,pull off front,remove old belt,put new belt with the ribbed side on drum,loop it around the pulley and motor under the drum,put back together,your done,good job-mike
Jun 17, 2009 | Kenmore 63942 Dryer
A circular belt came out of the back of the dryer?
The drive belt broke. ou need to replace the drive belt. Remove the back panel and you will see a motor and a pulley, attach the new belt there and it will work just fine. Here is a website to get the belt that is right for your unit.
http://www.repairclinic.com/Kenmore-Dryer-Parts?s=a8b6
Feb 10, 2009 | Kenmore 63942 Dryer
Putting a kenmore electric dryer back together
Your best bet since this will be hard to do without looking at it is to call a local repairman. There are too many things left to chance.
Dec 07, 2008 | Kenmore 63942 Dryer
Kenmore 70 series dryer
when you put your belt back on you must have had to take the front panel off am I correct? Did you forget to reconnect the door switch wires? Without them re-connected your dryer won't run.
Oct 26, 2008 | Kenmore 63942 Dryer
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Dec 03, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
172 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
