Question about Canon PIXMA MP600 all-In-One InkJet Printer
How do i fix a error 6502 on my printer - Canon PIXMA MP600 all-In-One InkJet Printer
  • 4,041 Answers
Hello
Try
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Posted on Jan 25, 2010
Error 6502 came up on my viewing box and I cant get it to clear. I dont know what caused it exactly. I had a paper jam and I pulled the paper out of the rollers to clear it now I have error 6502 and I dont...
Pls do the following :-
Error code 6502 The Error code 6502 can occur in the printer as a result of ink tubes caught under housing and jammed the print head against the right hand side of the printer. The printer is unable to do anything now and it will give an alarm light only. To fix this issue, you need to unplug the printer and then plug it back. You need to press and hold the power button of the printer and click the Stop button twice. You can then release the Power button and press Stop button for four times. The issue will be fixed and you can start your print jobs.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX700 Office All-In-One InkJet...
I have cannon IP3680, but from today it's making problem (Service error 6502), would u please tell me a easy way to solve the problem...
The error 6502 is an "Ink tank position sensor error". It may be that the sensor is dirty and needs cleaning. Make sure you haven't got any bright lights shining into the printer.
Mar 01, 2011 | Canon Office Equipment & Supplies
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
When printer is turned on error code 6502 comes on screen
Solution:
All Best: Pineworks
May 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error
Try
Solution:
All Best: Pineworks
Dec 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon IP4500 service error code 6502
canon pixma 4500 service error 6502
Jul 15, 2008 | Office Equipment & Supplies
Error code 6502
This might work
Solution:
All Best: Pineworks
Jun 14, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Nov 24, 2007 | OEM Systems PIXMA iP3300 Photo Printer
Error 6502
Have you replaced the ink cartridge recently? Service error 6502 is an ink tank position sensor error. Service error 6502 generally means that your ink cartridge chips cannot be recognised. The primary cause of this is the blockage of the LED. Ensure that no tape, glue etc is covering the chip or LED on the rear of the cartridge. Problem more prevalent on third party replacement cartridges or ink systems.
Jul 27, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
