Question about Gateway (M520HD80G) Hard Drive
I just replaced my hard drive and everytime i boot up it says found no operating system but when i try to install the operating system it wont let me
  • clinton_milt Dec 23, 2008
    to clarifation request milkbone it says gateway system recovery, no hard disk found. Gateway System Recovery cannot be continued!
  • Vince May 11, 2010
    What is the error that is displayed when you try to reload your OS?
    Novelist:
    Champion:
  • 254 Answers
New hard drives don't have an O/S installed, so they just be prepped and the O/S reinstalled, along with your applications.
Does your computer "see" the new drive? If the drive was properly connected, a modern computer will automatically detect it, and you shouldn't need to do much if anything in BIOS.
There is a key sequence to get into the BIOS setup, differs from computer to computer.
Assuming the computer detects the drive, the O/S install should partition, format, and install. Some SATA machines may not install Win XP without some additional work. Do you have the CD(s)/DVD(s) that came with your computer? If so, they should have all the proper drivers (including for SATA interfaced drives).
Hopefully this will help.
Posted on Dec 23, 2008
Sony vaio all in one wont start windows and says operating system not found
There are 3 possibilities:
1. The boot files are damaged/corrupted,
2. The hard drive's boot sector is damaged,
3. The hard drive itself is dead.
The easiest way to fix the problem is by buying a good working hard drive and install an operating system. Also, install a Norton Utilities (free, trial version) and diagnose the old hard drive. If the Norton Utilities can fix the problem, then you can use the old hard drive as a main hard drive, otherwise you can use it as a data storage.
Feb 20, 2014 | Gateway GT5678 Desktop PC
Operating system not found
Corrupt Boot Manager is the usual cause of this error. Insert your System OS disk and boot from it. Select repair.
Oct 25, 2013 | Computers & Internet
Acer aspire 7736/7736z series wont boot and operating system not found. Tried f8 just keeps beeping. Help.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 19, 2013 | Computers & Internet
Operating System not found
Im assuming you have an installation or a recovery disk
Insert the Windows install disk for your version of Windows and reboot the PC.
With the computer unable to find the operating system on the hard drive, it may skip automatically to the next possible boot device, which should be the CD or DVD-ROM drive.
Some systems may be configured to boot to that source first, and others may not be configured to roll over to the next device at all.
When in doubt, there should be an option to select boot device when the computer is first powered on (the F12 key on most Dell computers) and you can boot straight to the optical drive from there.
Press any key when prompted to boot to the install disk, then follow the on-screen instructions.
You'll want to try to perform a repair on the existing Windows install, which you will get to by first selecting a new install of Windows.
Select to install a new operating system, and the install package will look to see if Windows is already installed.
If it finds the existing install, the installer should give you a chance to perform a repair of what's currently on the hard drive, replacing corrupted files with clean ones from the install disk.
If the Windows installer does not detect an existing Windows install on the hard drive, then the hard drive itself may be at fault.
Replace the hard drive and repeat the first few steps to install Windows from scratch.
The original hard drive is likely corrupted or otherwise broken, and may not be recoverable at all, outside of an expensive, third-party data retrieval service.
hope this helps
Oct 11, 2012 | Sony Vaio Pcg-Fx140...
My mac wont boot up
you mean it does not go farther than the apple's logo? did you try installing a fresh copy of the operating system.while installing if you observe that it could not be installed then you should know that your hard drive needs to be formatted with zero-fill.
Apr 03, 2012 | Apple Mac OS X 10.4 Tiger for Mac
I have an acer aspire 5536 G, it had windows vista on it. Now everytime i try to turn it on it says that there is no operating system found. what can i do to restore it?
An error of no operating system found, is often an indication of a failed hard disk drive (HDD) in the system (The hard disk drive is where all data including Windows is stored)
  1. If the system is equipped with a floppy diskette drive, remove the diskette from the floppy drive and reboot.
  2. Re-seat the hard disk drive. (From time to time due to expansion and contraction the HDD may lose contact and is no longer detected)
  3. Once re-seated, reset the BIOS defaults (normally F2 at boot) then there is normally a setting to reload defaults. Resetting default settings forces the BIOS to re-detect all peripherals connected to the system.
  4. If you still get that error at boot, then it is very likely the drive no longer is functional and will need to be replaced.
Aug 05, 2011 | Computers & Internet
I just replaced my sony vaio hard drive in my laptop and it says operating system not found and wont finish loading up. what does that mean
It means the Hard drive is empty. Please insert the operating system CD boot through it from the boot menu and install the Operating system followed by Updates, Drivers and applications installation what ever you need..
Assuming you have XP here is the guide to install operating system
Click Here
For Windows Vista Installation Guide Click Here
Apr 07, 2011 | Sony Computers & Internet
Hard drive not found
Wayneard is correct. When you install a brand new hard drive as the ONLY hard drive in the computer, there is no operating system loaded. The computer will try to boot from the hard drive and stop. Switch your boot order to have the CD boot first, and be sure you have the operating system installation CD in your CD drive.
Also, double check your hard drive connections. Be sure it is in the "master" position on the hard drive cable. If there is a connection problem, the system will complain after CD start that there is no hard drive available to install the operating system on!
Good luck.
Dec 30, 2008 | IBM NetVista PC Desktop
Operating system
This will be either an operating system glitch of a failed hard drive. Start by doing a system repair with your recovery or operating system disc. If the repair doesn't take, then reformat the hard drive and install a new operating system. If the hard drive will not format, or you have any issues during or after the install, then the hard drive has failed and will need replaced.
Sep 03, 2008 | Sony VAIO VGN-S460 Notebook
Laptop wont boot
Every time I have had this problem, it was either the drive or the drive being reconogized in the BIOS, or a glitch in the operating system. I would go into Setup at the boot up and see if the BIOS is reconogizing the drive. If it does, then I would use the operating system installation CD but not do a install but use the repair feature. In the repair function run "chkdsk /r" many time this will cure a problem. BPCS
Dec 18, 2007 | Computers & Internet
Gateway (M520HD80G) Hard Drive Logo
287 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
