Question about Ovens
Lighting an old Frigidaire gas oven
I'm not that blonde, but I can't figure out how to light the oven on the old frigidaire I have. It doesn't have anything on the top, only one dial in the middle on the front of the range that says 'oven' on one side and 'temp' on the other. The dials for the burners have a 'lite' setting and they work just fine, but the oven dial just says 200 to 500 and then 'broil'. I had to bake cookies in my toaster oven yesterday - would like to use the oven today!! Thanks!
  • kjbakes Dec 23, 2008
    There are two slats on the floor of the oven on either side. Yesterday I tried turning on the oven and stuck a lighter in the gap, but nothing happened. I just tried it again and still nothing. How long would I have to wait for it to light? I assume I'll see or hear it light? I don't feel like I should have to wait too long with a lighter in there!! Would I smell the gas?
  • 28 Answers
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Posted on Dec 23, 2008
  • Ovens Master
  • 8,220 Answers
Checking the oven's gas safety valve lighting an old Frigidaire gas oven - oven%20safety%20valve.jpg pilotless safety valve used with ignitor Their are several different gas safety valves. On ovens with ignitors, if the ignitor is weak then the oven will not light off, but what if the igniter is new and the oven will not come on? An easy way to know for sure if that safety is bad is to see if it is open. If it has no continuity then the igniter is not going to come on. NOTE:Never put 120 volts to the safety valve in an attempt to make it come on. All you will do is kill that ******. It has to be hooked in line with the igniter to work properly. Why? The ignitor takes up most of the power. The power goes through the safety valve as 120 volts but because the amperage is all being hogged by the ignitor, the gas valve opens up and allows gas to flow out into the burner and ignite. Unless it is leaking most of the time the gas safety valve is NOT the problem. On ovens with pilot lights or standing pilots most of the time it IS the safety valve because the little thermocouple that mounts on the pilot goes bad and won't open the safety valve. valve with thermocouple Some ovens offer a seperate safety feature called a flame switch. What it amounts to is the thermocouple mounted on the pilot light goes to the flame switch which will have continuity as long as it is heated by the pilot light. flame%20switch%20type%20oven.jpg It allows for the gas valve to let gas out as long as the pilot is lit. flame%20switch.jpg flame switch NOTE: If you do have to replace the gas valve remember this: It will not come preset. You will have to adjust the flame height with a wrench. It is a good idea to set the 2 valves side by side, adjust the orifice height on the new valve to the same height as the old one and then you need only to tweak it a tad. If the flame is too low it will take 2 hours to bake a pie shell. too high and the bottom will be cooked before the rest. It is best to adjust the flame to about half way up the flame spreader. The ignitor glows but the oven will not come on. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. lighting an old Frigidaire gas oven - glowbar.jpgy the gas oven valve would be bad is if it is open and has no continuity. glowbar.jpg oven ignitor An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas: gas-ignitor-circuit.anim.5 . Click on image to see it in motion
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
  • Dan Webster
    Dan Webster Dec 23, 2008
    If you have a pilot light out you would smell gas in the oven from the lingering pilot gas. The pilot would be mounted on the burner and you would have to pull out the bottom drawer and lay on your back to light it.Open the bottom drawer and look for the burner. near the rear where it curves downward to the floor is the pilot assembly. I like to use a small propane torch to light pilots or a barbque stick lighter.
My Frigidaire gas oven won't light but broiler does light
Hello friend, thank you for your post!
From what you are describing it sounds like a potential issue with your control or pressure regulator within your Frigidaire oven. I would recommend seeking assistance from a professional for further help regarding the oven not lighting due to the gas.
If you need assistance connecting with a professional technician you can visit the manufacture's website for further help. -Matt
Oct 04, 2014 | Ovens
My oven stopped working on my frigidaire range. All top burners still work. What could be the problem?
Can you clarify a couple of things for me please:
Is this a gas hob and gas oven, or is the oven electric?
If it is gas, does it have a pilot light? (and is the pilot light on?)
If gas, does the oven light for a moment and then go out or does it not even light?
Jul 10, 2011 | Frigidaire Ovens
My frigidaire self cleaning stove(FGF368GM ) isnt lighting.... how do i light my stove?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gas Oven
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition. You can get a replacement at an appliance parts store. If you have a friend or relative who is a heating/air conditioning repairperson they can test your current igniter. Good luck!
Jul 10, 2008 | Frigidaire FGB24L2A Gas Single Oven
Frigidaire oven
Your oven valve won't open all the way
Aug 15, 2007 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
1,167 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
