Question about SanDisk Sansa m240 MP3 Player
I want driver for sansa sandisk m240 for windows xp proffessional
    President:
  • 948 Answers
No driver is needed, Windows XP has native support for this device if you are current with your Windows updates. I have used three different players this exact model. All you must do is connect the device to your PC with a USB cable and it shows up in My Computer.
If you are not current with your updates, go to http://www.windowsupdate.com/
Posted on Jan 10, 2009
Mi Sandisk m240 no la leen los pc
La compania Sansa tiene respuestas a varios problemas en espanol en este link: http://kb-es.sandisk.com/app/answers/list/search/1/kw/sansa%20m240%20manual , Quizas se encuentra alli una respuesta.
Paara pensar en soluciones a su problema hace falta mas informacion: el tipo de pc que esta utilizando (mac o windows, si windows, cual systema - windows xp, vista o windows 7?). El aparato m240 se enciende y reproduce la musica que ya tiene?
Hay dos modos de conectarse el m240 a un pc: MTP (Media Transfer Protocol) para sincronizarse a traves de un servicio como i-tunes, y MSC (Mass Storage Class), que actua como un usb Flash Drive en la compu. Posiblemente su m240 esta en modo MTP y si lo cambia a MSC se reconoce por el pc (vea http://kb.sandisk.com/app/answers/detail/a_id/207/kw/m240 en ingles).
Quizas si pregunta de nuevo en ingles recibira mas respuestas que le ayuden: My Sandisk m240 is not recognized by my pc, or does not appear in My Computer when connected to my pc.
Jul 04, 2011 | SanDisk Sansa m240 MP3 Player
I need a driver for my sandisk sansa m240. i have windows vista.
That model is not fully compatible with vista. So either it works or it doesn't. if not go back to using it on an xp machine.
Thanks,
lee
Aug 12, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 not being recognized, even after changing to msc
try this it is a driver for that specific MP3 player also if that download don't work search of Sansa M240 driver and other sites should be available for that driver to download
http://www.drivers.mrjuan.com/driver-5953-sansa-m240.html
Just select your operating system of course its XP download should start up hope this is helpful!!
Jul 26, 2009 | SanDisk Sansa m240 MP3 Player
Device driver m240
Uninstall all Sansa software using the add/remove programs function. Reinstall software from Sansa CD. Then and only then plug the mp3 player into the computer.
Nov 04, 2008 | SanDisk Sansa m240 MP3 Player
No drivers
ENGLISH
I had the exact same problem listed in this thread.
This is what I found on another site to fix it.
Make sure your M240 is not connected to the computer.
Then go into the "settings" menu and then go to the "usb" part.
Then Select "MSC" from the menu, instead of "Auto Select (or something like that).
Then turn off your player and connect it to the Win XP computer and it will be fully recognized
and you can then go to My Computer and see it there and use it.
SPANISH
Tuve exactamente el mismo problema mencionado en este hilo.
Esto es lo que he encontrado en otro sitio para arreglarlo.
Asegúrese de que el M240 no está conectado al ordenador.
A continuación, entrar en el menú "Configuración" y luego ir a la "usb" parte.
A continuación, seleccione "MSC" en el menú, en lugar de "Selección automática (o algo así).
A continuación, apague el reproductor y conéctelo a la computadora Win XP
y se reconoce plenamente y se puede luego ir a Mi PC y ver que hay y lo utilizan.
Dec 03, 2007 | SanDisk Sansa m240 MP3 Player
I WONT ADRIVER
Drivers are not necessary. You need Windows XP / SP2 and Windows Media Player 10 or higher. They supply all the necessary drivers. Best of Luck.
Oct 07, 2007 | SanDisk Sansa m240 MP3 Player
My sandisk sansa m240 not working with my windows xp pc
I have XP Media Edition w/SP2 and I see the M240 as a Media Device and NOT a hard disk, AND it has MEDIA and DATA subdirectories only. Media has to go into the MEDIA subdirectory to be seen/read played. Now, on my plain XP system, the M240 it shows up as a disk drive with different layout. There is no MEDIA directory, so putting files into the mass storage device letter will lockup the unit. I haven't tried Media Player 10 solution, but if you have one of these, do NOT put files in it unless you see the MEDIA subdirectory.
Sep 19, 2007 | SanDisk Sansa m240 MP3 Player
How to download the software of SanDisk Sansa m240 MP3
MY PLAYER HAS MUSIC LOADED THAT IS NOT VIEWABLE BY THIS TECHNIQUE BUT THAT IS ANOTHER PROBLEM THAT I CANT FIGURE OUT YET
Sep 05, 2007 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
159 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
