Question about Fahrenheat FUH5-4 Heater
Fahrenheat FUH 5-4B thermostat turns off at 40 degrees.
I have had this wall mounted unit in my garage for 7 years and it has worked well. This winter, the heater is shutting off at 40 degrees. Should I replace the thermostat?
Buffalo12980
  • 625 Answers
SOURCE: Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
the reset is probably an inline circuit breaker. if you can get hold of am amprobe clamp around ammeter, check the current when the unit is running at full power. the reading you get check against the current rating of the inline breaker. your fan motor bearings may be dry increasing the current draw of the unit and tripping the breaker. try oiling the fan bearings with a light oil NOT WD-40.
Posted on Dec 07, 2007
Therinnaiguy
  • 1420 Answers
Sounds like a bad temperature control switch. If it looks like it can be replaced, check with Johnstone or Grainger Supply company to match it up. Google it for their websites.
  • 18 Answers
SOURCE: black stuff on walls
your walls are trying to burn good thing you cannot turn it down it can kill you.
Posted on Jan 04, 2008
Accurate Joe
  • 61 Answers
SOURCE: add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Posted on Nov 30, 2008
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
Nov 28, 2013 | Fahrenheat 5,000-Watt Unit Heater FUH54
Installed my second Fahrenheat FUH 724 7500W heater in another garage. Installed same as previous heater that works perfectly. used 10 Gage wire and 40A 240V breaker (2-20A). Wiring is correct. Heater...
Could be either. But, I suspect that wiring is getting hot enough to trip the breaker. Check all of your wiring to see if there is a hot spot or insulation melted.
Feb 05, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a 724 heater7500 w 28x32x10 garage with dog door it will only keep garage at 40 degree not 50 like i want in minnesota what are my options
The heater is too small for the space you are heating....
You need to get a second heater or get a bigger heater to get more heat...
Heatman101
Nov 30, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I have the Fahrenheat Model FUH 724 heater. The manual states that it can be wired as a 240v 7500W unit but the directions and the unit itself only allow for three wires to be connected Black, White, and...
1st you will belucky if you actually have 240 v, most
homes are usually 220v. In youyr case you need to start at the breaker panel.
This is an example:
You have a Double Pole Single Throw breaker. Black
Wire is hot and goes into one side of breaker,if you havea red wire that goes into the other have of the
breaker.
The white wire ties in the nuetral bar and the bare wire into the ground bus bar. At the unit you hook up the red and the black wire which will supply the 240
Volts, you could tie the white and the ground wires together into the grounding terminal
Jan 01, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
Thermostat for Fahrenheat 5000Watt Ceiling mount heater
You could do it. It would mean serious wiring though and you should use the factory thermostat because it is designed to operate on 240 Volts. Or you could use a remote thermostat at low voltage to throw a relay in the heater and get it to come on. The manual has good diagrams on how it is wired and it would not be too hard to do. IT would operate just like the outside unit on an HVAC system .
Oct 26, 2017 | Fahrenheat Electric Convector Baseboard...
Fahrenheat fuh 54 b does not run long enough to get garage warm
have you checked what the operating amps are vs. the amps provided by the outlet. Sounds like you are trying to pull to much load and the machine probably has a saftey to where it shuts down bofore it buns itself up. Hope this helps. You have to be real careful about overloading circuts.
Dec 19, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
Dec 06, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat FUH5-4 Heater Logo
80 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
