Question about Numark TTX1 Turntable
Back and forth
My numark ttx1 is not making full revolutions it just goes beck and forth is there any one who knows what i have to replace or has ever heard of this problem before
  • 515 Answers
This is a common problem. One of the drive IC's has failed. You will need to have this professionally repaired.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
Numark ttx1 blowing fuses
Fuses blow when there's an overload. Most are caused by a semi-conductor that has shorted. If it was the bridge you can test with an ohm meter. Connection across it's leads will be just like touching the test probes together. That goes for any of the semi-conductor devices.
Mar 06, 2014 | Audio Players & Recorders
Numark ttx1 blowing new fuses
You are correct. Most are caused by a semi-conductor device. So the rectifier is a possibility. But also check devices with heat sinks on such as voltage regulators. Transistors and diodes and the transformer are easily checked with an Ohm meter. If it's faulty it will be just like you have touched the test probes together!
Mar 06, 2014 | Numark TTX1 Turntable
Numark ttx/ttx1 pitch fader wonky
Try spraying the slider with Servisol Video 40.
Mar 15, 2013 | Numark TTX1 Turntable
My ttx1 spins way too fast and wont slow down. all other controls and the display work fine.
Hello, did you get this repaired in the end? Same thing is happening to mine and I don't know what's causing it
Aug 19, 2009 | Numark TTX1 Turntable
Numak ttx1 turntable
If they are belt drive then you can get replacement belts from **** Smith Electronics for under 30 dollars if they are direct drive then you could check the fuses if its not either of these you might have to replace the motors which is quite inexpensive anyway
May 13, 2009 | Numark TTX1 Turntable
Tonearm base unit
You will have to order a new base, which is not cheap - about $150 - and replacement is a little complex, because you have to take apart your unit from the bottom.
- OPTiC
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Jan 14, 2009 | Numark TTX1 Turntable
TTX1 went wacky
These are drive issues. More than likely one of the drive IC's failed. This will have to be repaired professionally.
- OPTiC
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Nov 24, 2008 | Numark TTX1 Turntable
Play and pause button does not work
More than likely the button switches are damaged and need to be replaced. The CDMix1 is a very bad unit, chock full of issues. We wont even bother working on these anymore. This includes the CDMix 2 and CDMIX 3.
You might have to contact Numark directly for repair assistance on this one - www.numark.com
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Nov 02, 2008 | Numark TTX1 Turntable
Numark TTX1 Turntable Logo
246 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
