Question about Compaq Presario 700 470024-192 Notebook
Mouse is not working properly
The mouse is not working corretly, at times you have click several time before it clicks left side and the arrow is not working properly either. Hp send us to this website
  • Priya darshan May 11, 2010
    HI,
    Please reinstall the mouse drivers.To do that Please right click on My computer icon select properties and then in hardware tab select device manager(for Xp) or click on Device manager on the right side (for vista).
    After the device manager opens double click on "mice and pointing devices" under that right click on what ever name of you mouse is then click on uninstall,if it gives you a message whether you want to remove this or not say yes and then restart your laptop.This should fix the issue.
    Let me know the result.
  • 10,594 Answers
Please take out battery and unplug system then clean mouse pad with humid cotton cloth and let it dry and check.
Posted on Feb 08, 2009
    Sergeant:
  • 326 Answers
Try connecting external mouse and check out if that external mouse is working properly.if that is working then it must be internal loose connection problem.get it repaired.
  • Compaq Master
  • 19,396 Answers
Try first using system restore to a date before you had this problem, if this does not work, then you have a faulty pad.
  • Ginko
    Ginko Feb 08, 2009
    If you have had the problem recently, use system restore to restore the system to an earlier date, before you started experiencing the problem.
    If this does not help, or if you cannot do system restore, then you need to reinstall the system.
    Do a full backup of your files first, then use HP recovery tool, or the recovery CD to reinstall the system on your laptop.
    If you still have the problem with a newly installed system, then the mousepad is defective and must be reinstalled.
  • Ginko
    Ginko Feb 08, 2009
    Check also: HP and Compaq Desktop PCs - Troubleshooting Mouse Problems
    Here is how to do system restore: How to restore Windows XP to a previous state
    Here how to replace mousepad: COMPAQ Presario 700
    If you have lost the recovery CD, do not have a recovery tool, and you need to order a replacement recovery CD, then you can get it from HP for $10 , see
    Contact HP.
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
Touchpad stopped working
Use an external mouse to see what the device manager says about the touchpad. The device manager is in the control panel OR you can click start and type DEVMGMT.MSC and hit enter. Look for any ! or ? or X next to anything on the list.
Mar 16, 2013 | Toshiba Satellite Pro L640EZ1410 Notebook
The left click button on my Logitech M555b mouse stopped working earlier today for no apparent reason. It has no physical damage, such as dents, scrapes, or water damage. The mouse is only about 2 months...
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Or disconnect the mouse from your computer restart.
If still does not work you need a new mouse.
hope this helps
Sep 30, 2012 | Logitech Mouse Bluetooth M555b Black Pc...
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
Aug 02, 2012 | E-Machines eMachines Desktop PC
The mouse pad right and left clicks do not always respond
nope! the whole board matrix needs replacing. use a usb mouse
Aug 19, 2009 | Computers & Internet
Unresponsive left mouse click
I have that issue too. At the beginning I tought it was a connectivity problem but it does it even with the receiver side by side. Latelly it is working perfectly.
Jun 10, 2009 | Logitech VX Revolution 931690-0403 Mouse
Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
Mouse will randomly double click or have to click several times to work
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
Oct 18, 2008 | Logitech Cordless Mouse
Left-click of optical mouse is sticking
Yes open the mouse and clean the left click that should help if not is time to buy new mouse
May 26, 2008 | Logitech Cordless Mouse
Left click button not working correctly
Afraid it sounds like the mouse is the problem you can go into control panel, mouse, and change it round so u press the right mouse button to do the same thing. Sorry cant help anymore.. John
Sep 12, 2006 | Targus Kaleidoscope AMU0301 (AMU0301US)...
Compaq Presario 700 470024-192 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
