Washer won't drain or spin.
Model: 110.26294693
Serial: CJ 3005230
Washer won't drain. Can't remove outer cover either.
  • custserv554 Dec 23, 2008
    This worked out great. It turned out to be the switch - didn't know until I pulled the thing apart right down to the motor removal and inspected the triangle pin parts. A quick trip to the parts place and wha la! It worked like new! Thanks.!
  • Washing Mach... Master
  • 8,220 Answers
Kenmore top loader blues washer won't drain or spin. - direct%20drive%20cabinet%20removal.jpg Use a screwdriver to remove the screws holding down the control panel,then swing it upwards. Pop the s clips in the rear and remove the lid switch disconnect. Tip the case forward and remove it.You will now be able to repair the washer! The lid must be closed for spin. The lid has a striker in it that pushes against the lidswitch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. ls2.jpg here is a broken lid switch You can test the switch. If you have a meter. If not you can simply bypass this switch. In my left hand here is the lid switch male plug which I have removed from the lid switch harness. If I wanted to i could simply place a jumper between the 2 outside wires and the washer would spin. a%20lid-switch-unplug.jpg Do not leave it bypassed if you have small children or braindead brother in laws. a%20coupling.jpg A 3 piece drive coupling
NOTE: newer models have the screw hidden
dd%20washer1.jpg Here is a view of the washer with the case removed.
To get to the broken coupling
remove the pump first then
the motor,both are held
together with quick clips. a%20broken%20coupling.jpg pictured here is a broken drive coupling.
Line up the new part and replace
the motor, pump, and
case in reverse order. NOTE: This looks hard but if you take your time it is easy enough to save you big bucks! My friend RM made a 44 second movie on this subject. Click here to see it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 23, 2008
  • 5,911 Answers
I posted a solution for you on another post you had. Let me know if you still require assistance.
If you can't find your orginal post, let me know and I can assist you.
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore front-loader washer doesn't drain all the time. Seems pretty random. Took off the front cover and checked the filter basket several times - didn't see any evidence of blockage in the pump. When...
Jan 29, 2010 | Kenmore HE3T Washer
I have a maytag washing machine model PAV2300AWW that is leaking water and only draining 1/2 of the rinse load. Could this be a pump motor issue?
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 16, 2010 | Maytag PAV2300 Top Load Washer
During the spin cycle the washer does not drain the water. The cycle ends but the water remains in the washer. This happens in all of the spin cycles. I have a kenmore model heavy duty extra large capacity...
Jan 03, 2010 | Washing Machines
Kenmore washer model 11o 13 years old doesn't agitate or spin
If water does not Drain, follow the below guide to investigate :-
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer won't drain water or spin. I had this problem before and think I can fix. The part was below according the repairman but I can't figure out how to remove the cover to get to part. Help....
This is fairly simple to diagnose. Since the pump mounts on the motor and it is not pumping and since it is also not spinning therefore the pump does not work either then it can only be a broken lid switch.
Use a screwdriver to remove the screws holding down the control panel,then swing it upwards. Pop the s clips in the rear and remove the lid switch disconnect. Tip the case forward and remove it.You will now be able to repair the washer! The lid must be closed for spin. The lid has a striker in it that pushes against the lidswitch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. ls2.jpg here is a broken lid switch You can test the switch. If you have a meter. If not you can simply bypass this switch. In my left hand here is the lid switch male plug which I have removed from the lid switch harness. If I wanted to i could simply place a jumper between the 2 outside wires and the washer would spin. a%20lid-switch-unplug.jpg Do not leave it bypassed if you have small children or braindead brother in laws. hidden%20screw%20on%20dd%20washer.jpg NOTE: newer models have the screw hidden
Dec 23, 2008 | Washing Machines
My washer will fill up and drain, but it wont agitate or spin
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 11, 2008 | Estate TAWX700JQ Top Load Washer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
