AUTOMATIC car wont go in reverse, everything else works fine
SOURCE: GMC automatic transmission
I'm told and read a sun shell may be broke. Common problem for this vehicle. Shop will possibly rebuild and use aftermarket kit parts to correct problems the transmission had originally. Cost is probably between $1300 to 1600 to repair. Good luck I got the same problem on a 97 Jimmy and 3 shops said the same thing.
SOURCE: car will turn over but not start.97 audi a4 1.8
It sounds like you don't have quite enough juice to start it. Sometimes vehicles will turn over but won't start when battery is low. Have someone jump you with jumper cables and I bet it will start then have your battery tested. If it won't start try giving it a shot of starter fluid as well as jump starting it and this will probably do the trick. If not you will have to have it diagnosed professionally. Good Luck
SOURCE: 1996 Audi A4 2.8L will not shift into reverse or park
You need a new inhibitor switch on the gear selector.
SOURCE: 94 v6 camaro automatic.. no reverse or neutral.
Sounds like you may have burned out the reverse clutch pack inside the transmission by going from drive to reverse. I would recommend seeing a transmission shop for verification. Hope this helps
SOURCE: 1996 Audi A4 Automatic transmission wont shift when cold
Silly question: Have you checked the transmission fluid level, and is it to manufacturer's spec?
