Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
My Heater Sparks and shoots out smoke
I have a Coleman-Evcon heater for a 1999 mobile home. I just turned on the heat about 1 am yesterday morning, and it would not shut off. I had to throw the breaker to get it turn off. Then it blows out cold air all of a sudden. Now when it got turned on it sparked like it was going to catch on fire and a pillow of black smoke with something that smelled like it was fried came out. Can you help
Most likeley a bad transformer. Shut off the breaker, then remove the cover of the box containing the transformer & circuit board. If the transformer is bad, it will look and smell burnt. Mark the wires before you disconnect it, so you know how to connect the replacement. Then remove the bad transformer and bring it to a heating & AC parts store so they can match up a replacement part for you.
Posted on Dec 30, 2008
My Coleman Evcon furnace blows cold air even when the unit is turned off. How do I stop it from doing that?
Hello Rhonda Killalea,
On MOST furnaces built since 1960. there is provision
for the BLOWER on the old type THERMOSTATS.
BLOWER SWITCH ... has two positions
"ON" and "AUTO"...
(turn blower from on to "OFF" (or correct wiring)).
"AUTO" is the POSITION your thermostat NEEDS
to be on...
Only then will your heater's blower be under
control of those internal temperature controls.
I am including a SAMPLE page from the OWNER's
MANUAL... (a wild guess of which "EVCON" model
you might have)...
Without YOUR MODEL NUMBER... your answers
are going to be completely generic (pretty useless).
You will also need to disclose what model
THERMOSTAT you are using... while you are
LOOKING...
Try to note the FUEL you are using, HEATING
or HEATING-and-COOLING...
ELSE... my only suggestion would be to look
at the WIRES... note their color and CREATE
a TRUTH TABLE between the "typical" R,G,Y,& B
wires ( telephone wires ) and the ACTUAL
SCREW-TERMINAL designations...
Black, Brown, Red, Orange, Yellow, Green, Blue,
Purple, Gray & White... industry colors for
the possible TERMINAL designations... (and more)
THEN...
Go to the HEATER (air-handler or compressor)
terminal block and VERIFY .... The OLD FASHION
Red, White, Black and Green have a TERMINAL
MATCH from the thermostat to the HEATER.
Hope this helps...
Carnac the Magnificent
https://www.manualslib.com/manual/500880/Evcon-Eb-Series.html?page=2#manual
Evcon EB SERIES Owner Manual Page 2
Feb 20, 2018 | Coleman Heating & Cooling
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
Coleman Evcon AH Series heat pump and the status light blinks
NO you cannot. I also advise you to completely disconnect all power to it until ready to do the work, you may cause a fire otherwise. Be safe.
Feb 03, 2010 | Heating & Cooling
I have a coleman evcon furnace that wont work. The electrical box green light is not on at all so it cannot pinpoint what the error is. Any thoughts?
Hi, I would just make sure you have power to the furnace. Check breakers or look for the power switch on the electrical box. Also, some mobile homes have a wall switch that cuts power to the furnace.
Jan 16, 2010 | Coleman Propane Forced Air Heater...
I JUST BOUGHT A USED COLEMAN EVCON FURNACE MODEL #BGU09516 AND I NEED TO KNOW HOW TO VENT IT. PLEASE HELP, THANKS
It should have a two part chimmney with a 4 inch inner exhaust section and a larger 6 inch outer section that goes over the flange on the top of the furnace. If your existing chimmney does not have this you may have to buy a chimmney kit for a mobile home application.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Rollout Limit Switch Keeps Tripping
have someone check the gas presure most likely too high no more than 11
Dec 14, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
94 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
