Question about Brother IntelliFAX 4100 Laser Fax
Black page when copying and sending faxes.
We can receive ok but will get a completely black page when making copies. Other people state the faxes they receive from us are black. No error messages.
    Genius:
  • 2,120 Answers
You most likely have a bad SCANNER BLOCK. Not good!
Posted on Dec 25, 2008
Sharp UX B700 when sending fax the receiver received a black page.
Dear
Pl. make a copy on your fax machine, if its ok, then your fax machine is OK. else your scanner and related part may defective. However this may tested after SHADING ADJUST done on service mode.
Thanks.
Feb 25, 2015 | Sharp Office Equipment & Supplies
Black line down left side of sheet, if i'm copying a page that is and i can't get rid of it no matter what i try i've changed the drum and the toner and still get a line down the whole sheet
If the received fax's are ok and there is no line; and you only get the line when you make a copy....I assume the people you send to are also getting the black line down the page,?? then the problem is in the optics...favorite is some kind of dirt, glue, or corrector fluid on the glass that the original passes over when you make the copy.
Aug 20, 2010 | Office Equipment & Supplies
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
Nov 04, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
On sending a fax the receiver copy has a black
You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
Totally black transmissions
Copy lamp has blown, light should shine in where original is placed.... it isnt lighting the paper up, so reflection received is black hence black transmit/copy result
It is just a small specilised floro but would probally be more ecomomical to replace machine than to fix it.
Nov 19, 2007 | Brother Personal FAX-190
Brother IntelliFAX 4100 Laser Fax Logo
221 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
