How do i bypass lid lock switch
SOURCE: Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
