Question about Minolta magicolor 2200 DP Laser Printer
Are you there? I have a problem with a Minolta 2200 as to the error about replace the transfer belt . Can you help
    Sergeant:
    Champion:
  • 275 Answers
Contact minolta tech support coz they will tell you how to change the transfer belt if you do not know any thing about printers get profeshinal help
Posted on Dec 23, 2008
Konica Minolta c284 error p-21
Code
P-21
Description
Color regist test pattern failure. • During pre-pattern detection, pre-pattern edge (start/ end point of effective area) is not detected within the pre-pattern search area. • During detection of regist pattern at vertical/horizontal direction, pattern edge (start/end point of effective area) is not detected within the pattern search area of each unit.
Causes
• Transfer belt unit • PH unit • IDC sensor shutter solenoid (SD2) • Front side board (FRB) • MFP board (MFPB)
Remedy
1. Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty. 2. Replace the transfer belt unit if the transfer belt is damaged. 3. SD2 operation check. 4. Replace the PH unit. 5. Replace FRB. 6. Replace MFPB.
Konica Minolta bizhub C558 Error Codes
Jul 16, 2018 | Konica Minolta Office Equipment & Supplies
Minolta ep 1030 error e1
Imaging unit toner detection failure - during concentration read operation (F8), the result is less than 1v. Replace the developer and retry the F8 procedure.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 18, 2014 | Konica Minolta Office Equipment & Supplies
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
My Magicolor 2200 ghosts in color and in black. Ghosting appear about 1/2 way down an letter size sheet. Installing new fuser has no effect.
This is a symptom of a well-used transfer belt. Replacing it should do the trick.
To verify: Check the transfer belt. The transfer belt is the large replaceable unit close to the center of the printer. It should have excess toner clinging to it. Don't bother trying to clean it off. It will just return the next time you print.
I'm currently looking for a way to squeeze a little more life out of it. But, am having no luck so far.
Nov 29, 2010 | Minolta magicolor 2200 EN Laser Printer
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
Magicolor 2200 DL - replace transfer belt
Is this an error 16 rorate problem? It does seem weird that you still get it having replaced the transfer unit.
However the printer does have a nasty habit of not re-setting things correctly - it creates the error message by blowing a fuse on the unit and it has been known to do this even when a new unit is put in.
There are a couple of places on ebay that sell a kit that explains how to get to the fuse and they supply a new fuse. It appears to be a 1/4 amp slow blow fuse
To get at it you will need to unscrew a black plastic plate at one end of the transfer unit (it is the one that has a square hole with the main electrical contacts poking through. Loosen the 2 screws and remove. the fuse is on a small circuit board that is easily removed. replace teh fuse (needs soldering) and this might do the trick. If you have a tester might be worth removing the small circuit board (wire connector comes off easily) and checking.
This fues usually blows when the transfer unit is old and a sensor unit gets clogged up. However even when teh sensor and the band at the side of the belt has been cleaned the fuse still sometimes blows.
This might solve the problem.
Sep 26, 2009 | Minolta QMS 2200DL Laser Printer
The 2200 uses fuses, that when first inserted into the printer reset the counter then blow. Once blown (used in your other printer) they will not reset the counter on a printer. There are posts elsewhere on the net on how to replace the fuse, or bypass with a paperclip in place of the fuse.
Dec 23, 2008 | Minolta QMS 2200DL Laser Printer
FUSE FOR TRANFERBELT
Are you sure you have to replace the fuse and not the fuser unit? What symptoms does your printer show and is there an error code? Most of the fuses are on the HV1, HV2 or PU1 and will be either 5, 10 or 15 amp.
Mar 08, 2008 | Minolta magicolor 2200 DeskLaser Printer
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
Minolta magicolor 2200 DP Laser Printer Logo
101 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
