Question about Panasonic WORKiO DP-6030 All-In-One Laser Printer
My Dp-180 has an error J01
My printer has an error message "remove misfed paper J01..i have tried to switch it off  and on but its still there..i have also checked for any stuck paper but there is none...what do i do?
    Sergeant:
  • 284 Answers
There is a tab at the back of the tray , make sure it is pinched up to the paper.. and take all the paper out and see if there is any folded paper at the bottom it not.. msg me directly and we can try one more thing
Posted on Dec 30, 2008
J01 error, but no paper jam; can't re-set
Remove the toner cartridge.
There should be 2 switch actuators sticking up from the base.
It sounds like one of these actuators has been knocked loose. Try to clip the actuator back on to the sensor.
This is a TOUGH job, you may need a sercive tech to look at it.
Oct 13, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Can not print and photocopy on panasonic dp-2330
Hello sir; Check the paper path where the paper stuck,there have a senser , may be come off or out of track, just put it back to right place.
May 15, 2009 | Panasonic WORKiO DP-2330 Copier
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
Jan 13, 2009 | Panasonic Workio DP-190 Multifunction...
I have a panasonic workio dp1810p printer/copier. Everytime that I turn it on I am receiving a "Remove Misfed Paper J92" error. I cannot find any paper jams and am having trouble finding out...
You could try the technique Peter, Samir, and Michael did in office space the movie. I find this technique to be quite effective for most problems with electronics in general.
Jun 28, 2008 | Panasonic DP-4510 All-In-One Printer
Panasonic DP-1810P Laser - J41 error code
i think the fuser sensor lever on your machine is damaged.
its the lever that you usually see when you open the cover the fuser unit.
Apr 02, 2008 | Panasonic DP-1810P Laser Printer
Misfed jams
First off, does the wheel indicate the proper size paper. Be sure to place close attention to the icon. Second, when you slide the drawer out, in the middle of the right edge, there is a spring loaded pad. Carefully peel the cork off, and rotate it 180 degrees, or you could switch it with the other drawer. Other than that, there might be a small wedge of paper in the lower switch, located in the middle of the paper path, between the paper guides. It may be next to impossible to see unless it is taken apart.
Feb 21, 2008 | Lanier 5222/27 Laser Printer
Panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
Panasonic WORKiO DP-6030 All-In-One Laser Printer Logo
364 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
