Question about Rio HT2015 DVD Player / VCR Combo
Rio HT2030 disc loader will not open - Rio HT2015 DVD Player / VCR Combo
  • carps40 Mar 19, 2009
    How do you take it apart to replace the rubber bands?
I have had the same problem. There is a rubber ban that acts as a drive belt to open and close the disc loader. i took the cover off and then the disc loader cover off to expose the bubber ban. Then i replaced it using two rubber bans from my daughter's braces and reassembled. Works great again.
Posted on Dec 31, 2008
I just did this fix as well and it worked great. To take it apart, remove the 7 screws from the outer cover (3 in the back, 2 on each side). Then slide the cover back and lift it away. If you can get the tray to open partially, you won't need to remove the disc loader. Press the DVD eject button and then "assist" the tray to a half-open position. Through the center of the tray, you will now be able to see the rubber band running between two wheels at the front of the drive. If the rubber band is the problem, it will either be broken or hardened. Remove the old one and carefully mount a replacement rubber band on the two wheels. Make sure it has a decent amount of tension on it when it is in place. Then try the eject button again. The tray should now open and close smoothly. Reattach the outer cover and you should be ready to go!
Posted on May 31, 2010
Tray will not open. Says check desk.
Three reasons.
1. a worn up loading belt at the disc loader mechanism.
2. a broken gear wheel at the disc loader mechanism.
3. a damaged disc.
Mar 05, 2016 | Televison & Video
CD/DVD drawer won't open so CD stuck inside :(
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
I have a Rio HT2030 Home Theater manufactured by Sonic/blue. When I placed a DVD in to play, I received an error message, could not read. I put in a CD in the same unit, and it played the music CD. I know...
did you try 2 or more dvd's
if that does not work the motor that spins the cd/dvd is faulty.it can also be the lazer so try other dvd and the see what happens
May 11, 2009 | Televison & Video
Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Jan 18, 2009 | Sony DVP-CX860 Multi-disc DVD Player
WILL NOT READ SOME BOUGHT MOVIE DISCS
one of the solutions before spending $$ is, you need to open the unit remove the dvd loader,CAREFULL OF PLUGS AND RIBBON CABLES!!! open the dvd loader, clean the laser GENTLY WITH A CLEAN COTTON TIP, and re assemble. if that doesnt fix the units issue,the second option is you will need to replace the dvd loader, part number is found on white or yellow sticker. hope this helps.
Dec 20, 2008 | LG RH1999H DVD Recorder/HDD Recorder
RH1888HS /hdddvd
what you need to do is open the unit carefully remove the dvd loader, open it and gently clean the laser with a clean cotton tip, if that doesnt fix the problem you need to replace the units dvd loader. part number found on white or yellow sticker on dvd loader. hope this helps.
Need Rio HT 2030 stereo owner's manual
Try Googling (rio)(HT2030)(manual) without parens.
Aug 07, 2017 | Televison & Video
Rio HT2015 DVD Player / VCR Combo Logo
443 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
Jaime Hernandez
JOHN TOPLISS
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
