Question about ECHO, Inc. 20 In. Double Sided Hedge Clipper
Putting gears back in echo trimmer
Took trimmer apart -it was locked up inside -took gears out -cannot get the gears back in to seat properly.can you provide a picture as to how the fit .-I paid attention when taking apart-help pleeeeeeeeeeeeese
  • Antonio Boscia
    Antonio Boscia May 11, 2010
    what is the model and serial numbers?
    Scholar:
  • 76 Answers
Go to www.echo-usa.com/documentation.asp youll need your model number and you can get a breakdown of your machine which should help you to get it back together a little easier.
Posted on Jan 05, 2009
Why does my echo 230 weedeater not throttle up
This is usually a result of the diaphram in the card being too dry to open and close properly fromt the vacum of the engine. I have replaced just the diaphram for around 12 bucks or replaced the whole carb from Ebay etc around 30 to 50 bucks.
Jul 12, 2014 | Echo Garden
Where do I find a picture showing internal parts for gear box on Stihl KM130 Hedge Trimmers
we have require heavy gear box inspection tool without opening the top cover
Jul 07, 2012 | Stihl KM-130 Hedge Trimmer
On my echo weed trimmer the rope broke on the starter. i took it off and the spring came out. how do you reconnect all the workings?
Recoil starters can be very dangerous when coming Apart!!, And During Reassembly!! Please do not attempt unless you are a qualified and certified Echo technician!
The spring of the recoil is what pulls your rope back in, It is of high energy and can harm you during Assembly, if you fail on any one detail. The most common injury is to the eyes! Use proper eye safety when performing repairs on recoil starters!
Re assembly process as follows,,
For parts info, go to http://www.powermowersales.com
Jun 11, 2011 | Garden
Hello I have an SRM 240 Echo Weedwacker . I was dumb enough to try to take off the head and put a new head on - the new head I had was the wrong head so now I am lost on how to put the first head back on
Please see page 14 of the following manual for detailed instructions (including tools to use) in order to accomplish this procedure. You see, you have to lock up the gear drive so you can get the head back on the threaded end of the driveshaft.
http://www.echo-usa.com/pdf/documentation/SRM242410ES_042198.pdf
Jun 05, 2011 | Echo Rapid Loader, Trimmer Head
Just got new U Turn Trimmer head. It has line inside the head. I cannot get the thing apart to get to the line. It is not like the unit I took off from my Echo.
push down and turn until it comes back up...now, on that spot that is all the way in, before it comes back up, pull up on it...got it ?? The release is located where the the spool is all the way down and getting the spool to "hang up" on that spot allows it to release...because it can't when running makes it a perfect location
Apr 17, 2010 | Echo Rapid Loader, Trimmer Head
Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Apr 13, 2010 | Craftsman 25cc Gas Line Trimmer
Echo gt 200r trimmer not spinning
there is a cable inside the tubing shaft you must separate engine from tube to access
Jul 17, 2009 | ECHO, Inc. PB-251C Handheld Blower
Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
Trigger jamming
I suspect that the cable to the carb is binding. Make sure when you reassemble the box, the cable works properly. Put the box together loosely and keep checking the action. Position the parts if it binds. Good luck!
Mar 20, 2009 | Echo Garden
ECHO, Inc. 20 In. Double Sided Hedge Clipper Logo
428 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
