Question about Philips Magnavox TS3260C 32" TV
Manavox set up
Just need know how get in the sistem to adjustment the vert size on my 19'magnavox model mt1901b101 also if these set work with 130 vdc or less... any help aprecciate thanks
    President:
  • 1,284 Answers
The set works on 110-120 volts alternating current only.
Posted on Apr 26, 2007
How do I get this black bars out of the picture of this crt? I tried some diy degaussing techniques and that didn't work. I hope this could be fixed cheaply.
First you need a signal because there is no synch without it.
Then if the problem is still there look for Vert size, Vert Hold adjustments
Mar 10, 2016 | Televison & Video
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Is a manavox mbp5120F compatiable for nex flex?
"Walmart had two models the MBP5120f and MBP5130f. Apparently they mislabed the 5120 on the internet as being able to stream netflix. I know this because I bought the 5120 and couldnt get nextflix to work. I even called Magnavox and confirmed that it was not netflix capable. Therefore I took my 5120 back to walmart this evening and complained and they easily swapped it for the 5130 which IS netflix capable. Tonight at my local walmart it still rang up for the same price of $69 as the original 5120 they had posted."
To answer your question I copied this blog which states the P5120f is not compatible with net flix. The 5130 is.
May 07, 2014 | Magnavox MBP5320 BLK Blu-Ray/DVD Player
Fios Remote and Tv Codes
Go to lidl store and buy a universal remote control for £6,the sheet that comes with the remote has thousands of codes but the nearest i see to yours is MAGNAVOX. Hope this helps. Ted10
Jan 06, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Magnavox 9p6034c 60in projection tv
I fixed my problem,it was the optocoupler no 7412 on the large signal board,the TV
wouldn't come on at first,so i disconnected the audio amp and convergence
boards to check for a short,after which it started to stay on,with them disconnected. I was then able to check the 130 volt supply.It was only reading 104 volts and would not respond to any adjustment to the pot. when i changed the 7412 opto the 130 volt supply started working and i was able to adjust it.Now if i can replace the crt coolant and put it back together without breaking anything.I purchased the optocoupler from
mauser electronics the number is HCNW136-000E for $1.80 each
PS:figured solution after reading a few post.
Jun 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Need the code for my remote
codes for magnavox tvs: 0054, 0030, 0179, 1254, 1454
the programming procedure is as follows:
1) turn on tv
2) on the remote, press "tv"
3) press and hold set until the led blinks twice, release set
4) enter the 4 digit code, light should blink twice
5) aim remote at the tv and press power, the tv should turn off
6) if it doesnt, repeat steps 2-5 with the next code on the list
hope this helps
Nov 17, 2007 | Televison & Video
Magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Sep 10, 2007 | Sanyo DS19310 19" TV
Vert adjustment
To enter the service menu (use the button on the set)turn on the tv, then turn it off, using remote enter 2, 7, 1, then mute with in 5 seconds. Then press 9 and select V-S, display chnages from V-S and V-P. Then use channel up and down to adjust. When down use the power on the set to turn it off.
Apr 11, 2007 | Philips Magnavox 20MS233S 20" TV
Picture squnches into a thin line in center of screen
this set is known for cold solder connections on the vert output as well as the b+ supply line comming from the flyback xformer that supplys the voltage to the drivers. It could also be the vert output capacitor, The two waveshaper caps in the predriver stage of the vert, the filter cap off the flyback or the vert drive b+. Without going in and getting a schematic it will be hard to say. sets like that unfortantly these days are throwaways. NO NO NO dont throw the set at me I did mean that way!!! Its the cost factor of repairing getting the parts as well the the service diagram. it all adds up.
Mar 25, 2006 | Emerson TS1997 19" TV
Philips Magnavox TS3260C 32" TV Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
