Question about Dell E153FP 15" LCD Monitor
Menu keeps popping up; Stuck buttons perhaps?
Hey guys i recently got a Dell E153FP Monitor and recently the Menu kept flashing up and when I'd hit the Menu button to make it go away the menu would just be there and all the buttons are unresponsive except the power button. Also The menu will go away then a lock comes up in the middle of the screen and it will appear locked then be unloocked and it does this at random times making it hard to do things...Any ideas?
  • mysticelf99 Dec 23, 2008
    Okay so if a stuck key is the problem(most likely is) how do i go about fixing it?
    Like do i need to take my monitor apart or what..?
    Alright, thanks. Will do.
    Novelist:
    Champion:
  • 254 Answers
Yes, a stuck key would be a likely culprit. Sometimes a key will get stuck out of just plain useage/wear, or, pop or other liquid spill or splatter will result in a sticky key. Press on the suspect key-compare to another key- different feel will tell you a problem exists.
Low cost keyboards don't generally have the life expectancy as older higher quality ones. Laptop keyboards are also more fragile, and subject to problems.
Posted on Dec 23, 2008
  • Merwyn Bolles
    Merwyn Bolles Dec 23, 2008
    After looking more carefully at your description--- You are talking about the buttons on the monitor itself- I was thinking keyboard- oops! Ok, the problem is likely the same though- the menu button/switch is either activated, or something in the logic circuitry is fouled up, making it look like the button is pressed. If it is logic problem, user repair is doubtful at best.
    You may be able to take the unit apart and find the problem, if it is a button/switch related. Sometimes there is a tiny switch (tact switch) behind the individual buttons. Or, there the buttons may be part of a rubber like pad with a conductive area, which comes in contact with a matching area on a circuit board. (This latter is like most current remote boxes). If either the switch is activated or the pad area is in constant contact with the circuit board, that particular function is activated.
    My guess is, that something went awry in the assembly process and the buttons are positioned too close to the switch or board assembly, and this must be corrected.
    One other possibility- there is a short- perhaps a solder bridge- maybe where the board wiring harness is soldered to either the small circuit board where the controls are located, or where the harness solders to the main board.
    If this monitor is under warranty, I'd just take it back for an exchange.
Main Menu Keeps Popping up
The only suggestion I could make would be to consider opening the monitor up and inspecting the control panel for a stuck button or damaged control. While this is feasible, the real question is whether it is cost effective if repairable. The ever decreasing cost of equipment is making monitor replacement very affordable, even if it is filling our landfills with junk.
Apr 12, 2010 | Dell E173FP 17" LCD Monitor
Dell E153FP main menu keep popping up
Main menu button on OS buttons is stuck,
Contact Dell Techncial support for repalcement Monitor
Jan 05, 2010 | Dell E153FP 15" LCD Monitor
Dell E153FP main menu keep popping up in the middle of mt screen
check to see is ur button stuck for some reason. most times it is because of greasy fingers.
Nov 27, 2009 | Dell E153FP 15" LCD Monitor
The brightness/contrast box keeps popping up without any buttons being pushed and sometimes scrolls through the options with nothing being pushed
There might be dirt underneath or close to the buttons.Try some compressed air to remove any dirt that might be there.Remember to unplug the monitor before you try to service it.
Good Luck
Oct 22, 2009 | Dell E153FP 15" LCD Monitor
Menu screen keeps popping on and off during usage
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Jun 01, 2009 | Dell E157FP Monitor
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E153FP 15" LCD Monitor Logo
308 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
