Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Marks on Screen
I picked up this unit second hand unit. There are some bright magenta marks that are vertically aligned in the centre of the screen. They look like drops of liquid but this is only visible when the unit is on. Is this likely something that needs to be cleaned inside the unit?
  • Ken Burgess Apr 24, 2007
    I opened it up and could see nothing on the inside of the screen or on the mirror that would cause this. I cleaned the lenses, closed it up and the problem remains. A picture is attached.
    Scholar:
  • 77 Answers
These are burn marks on one of the picture tube, probably the green one from the looks of your picture (the absence of green will leave red and blue)This happens as the result of some kind of previous failure, hopefully that has been repaired now. However the marks will always remain unless you replace the green picture tube which is costly and which is why they sold the tv. Sorry about the bad news, if you decide to have somebody replace the tube for you make sure they look for what burn't it in the first place it could be intermittant and waiting to happen again to your nice new tube. Although seeing what model this is this tv did like to do this when the convergence failed in which case it looks like that has been repaired already. Good Luck, hope you didn't pay too much for the TV.
Posted on Apr 25, 2007
How can I get "clean" prints without marks on a Xerox Work Centre 7428?
Hi Tommy yea that is usually a image unit problem. Looks like the drum is scratched up. I looked at the pictures looks like the cyan image unit is bad. Take them out carefully... and keep them away from light and you should be able to see that chip in the drum. Might be hard to see it. We sell those image units iteminconline you can also give us a call and we would be happy to help you.
Sep 03, 2014 | Xerox Office Equipment & Supplies
What are the timing marks for a 1998 mercury mystisque 4cy....I need to know how to position them
1998 Mercury Mystique 2.0L MFI DOHC 4cyl
align the camshafts and the...
Fig. 5: Alignment marks for timing chain installation-left hand side
Fig. 6: Alignment marks for timing chain installation-right hand side
Hope thats help.
Feb 02, 2010 | 1998 Mercury Mystique
Set harmonic balancer to top dead centre,set cams to timing marks,engine will not start but turns over. Hyundai Terracan 2002
hi from uk assume you have renewed c/belt and balance shaft timing belt? if so? and sure your timing marks on cams and the c/shaftcog are correct ? the oil pump also correctly aligned with marks? and the balance shaft gear also has time marking ? want to run thro how and which marks you have aligned and at TDC No1 all belt/s have to be aligned ??
Dec 27, 2009 | Hyundai Sonata Cars & Trucks
Timing belt alignment marks to replace broken belt.
broken belts on these engine can cause engine damage...the are 2 belts on the ohc engine,
align the timing mark on the bell housing with the centre of the 3 marks on flywheel ( no numbers etc) the others are ign timing marks..each camshaft sprocket has a mark on it and on the cover above it make sure these align also.
Nov 05, 2009 | Subaru GL Cars & Trucks
PAIRS OF GREY MARKS GOING DOWN THE CENTRE OF MY TV
YOU HAVE A PROBLEM WITH THE LCD PANEL. SONY DOES NOT CONSIDER THIS AN ISSUE AS NO ONE WATCHES A WHITE SCREEN.
Jul 17, 2009 | Sony Televison & Video
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Screen showing marks when playing a full screen video
If you get the problem on startup and externally then it's the GPU. You can fix it by reflowing the GPU on the motherboard, but it's NOT easy for the average user.
You might be able to find someone on Craigslist who can do it. I'd pay no more than $50 for someone to do it, but depending on where you live the price could be higher.
One thing you could try is to update the bios firmware. It's definately worth a shot.
Let me know what happens.
May 11, 2009 | Acer Aspire 1800 Notebook
Horizontal lines on picture
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Nov 26, 2008 | Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Lexmark C752DN
Follow the steps in htis link it may help:;;
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:409:0:0&framed=&docid=ENUS21576&relevance=1
Feb 13, 2008 | Lexmark C752dn Laser Printer
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
