Question about Honeywell Programmable Thermostat Heater
Thermostat (Honeywell T834C1137) temperature control not working
My thermostat's temperature control is not working. It does not stop heater once the preset temperature is reached.
Therinnaiguy
  • 1420 Answers
SOURCE: Won't shut off when reaching preset temp
Sounds like a thermostat problem or a short in the wire. Can you give us more info like is it gas or electric and model numbers will help.
Thanks.
Posted on Oct 11, 2007
SOURCE: Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Posted on Jan 23, 2008
heatman101
  • 43501 Answers
SOURCE: Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 12, 2009
  • 58 Answers
SOURCE: I just bought a Honeywell RTH2300B and installed
I WOULD AGREE WITH YOU, I WOULD RE CHECK THE WIRING TO MAKE SURE IT IS CORRECT, THE KEY BEING THAT IT WORKED WITH YOUR OLD THERMOSTAT, GOOD LUCK !
Posted on Jan 29, 2010
  • 4134 Answers
SOURCE: How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Posted on Jan 10, 2015
Heating not working and Honeywell Thermostat Heater states that the temperature is 45 degrees celsius.
without seeing it its hard to say, the thermostat controls the boiler and/or diverter valve depending how its been wired, the diverter valve shunts the water to were its needed ie from one circuit to another if you have two therostats there is a conflict somewere, best bet to have an engineer sort the wireing out
Dec 28, 2011 | Honeywell Programmable Thermostat Heater
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Loss of temperature control
Is the heater staying on all the time? Most likely cause of themostat trouble is the sensor. Try to find it and measure its resistance at different temps to verify the trouble.
Dec 31, 2007 | Honeywell CT3200 5-2 Day Electronic...
Does blocking thermostat stop heating
you mean like putting a box over the thermostat? the air inside the "stat" will get to a temperature and stop the heating. when the temperature inside drops, the thermostat contacts close again and the heater starts again.
Nov 25, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
431 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
