Question about Indesit Washing Machines
The belt from an Indesit washing machine broke a wire
The belt from an Indesit washing machine broke and it broke also a en electric wire that I don't see exactly from where it comes. Could anyone help here? Thank you!
  • 3 more comments
  • nicolae_crud Dec 23, 2008
    The model is Indesit WI 105 or WIL 105. The wire colour is Yellow-Green, same as another one which is still attached near the engine.
    There are 2 wires Yellow-Green and one of them is pulled off completely and the other one is still attached but only at one end and I cannot see where to reconnect them - there seem to be 3 connectors where these can be attached: 2 on the motor and one to the left of the motor, but I am not able to make a difference.
    The connectors do not have any colour and I am not able to identify where to connect the 2 wires Yellow-Green. I attached a picture which shows the situation.
  • Barry Coates
    Barry Coates May 11, 2010
    What model is the washer, and what colour is the wire plz?
  • Anonymous Mar 18, 2014
    belt broke wires broke all fixed dut machine wont light up when switch on
  • Indesit Master
  • 3,463 Answers
The wire you refer to is an earth wire, it has probably pulled of the motor or the frame of the m/c.
If you can't see where it came from, don't worry too much, all you need to do is fasten it to a metal part of the m/c so that is is making a contact to earth.
I assume that you can get a belt o/k
Make sure that the drum and motor are free before you fit new belt.
Plz rate my solution
Thanks.
Posted on Dec 23, 2008
  • Barry Coates
    Barry Coates Dec 23, 2008
    If any of the connectors are green yellow, then it really does not matter, so long as you connect like for like, it will be o/k, and like I said before so long as you are connected to a clean metal psrt of the chassis, then every thing will be o.k..
    It will be safely earthed.
  • Barry Coates
    The end of the earth wire has what is called a spade terminal, look on the motor body near the motor plug for a terminal that the spade connector will fit too, or see if you can see one attached to the chassis of the m/c.
Dryer not working indesit
Hi.
Is it a condensor or vented dryer.
Jan 04, 2014 | Washing Machines
No power indesit iwe8123
Most likely control board is defective If all machine is checked for power
Dec 09, 2013 | Indesit W 123 Front Load Washer
Hi My Indesit washing machine is not spinning it sounds like the function of spinning but without the movement.
hi if the motor is running then sounds like belt has come off if you replace the belt and it happens again then it could be the bearings or pully wheel
Jan 09, 2011 | Indesit Washing Machines
The belt on the indesit dryer broke. Bought a new one but what holds the drum in the machine
Pop the top ... probably 2 screws and spring clips. Remove the front, be careful of the wires attached to the door switch. You will see how it works when you tip the front back toward yourself.
The back sits on two wheels and the front rides on a felt "bearing" around the door.
If you need more help, let me know
a
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Boiler broke down
if you have two hoses going into it probably not
Jun 10, 2009 | Indesit W 123 Front Load Washer
INSTUCTION MANUAL REQUIRED
This online company list all Indesit WM manual:
http://www.unbeatable.co.uk/manuals/Indesit-Washing-Machines/27916330.html
From them:
Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
no_image_large.jpg Read & download instructions & manuals for your Indesit Washing Machines product, to help you install or troubleshoot any problems. Check out these manuals to help you set up & get the most out of your Indesit Washing Machines product.
May 26, 2009 | Indesit Washing Machines
Indesit 123 not rotating
Mine did this today, but we fixed it. Just the belt had come off.
Disconnect from electric.
Remove back panel by removing 5 or 6 screws with a screwdriver.
Put belt back on.
Screw back panel on to machine again.
Sorted !
Dec 12, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Washing Machines Logo
744 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
